question about eye blinking in ct5
https://forum.reallusion.com/Topic3189.aspx
Print Topic | Close Window
By leeannlacy - 18 Years Ago
Do you have to use puppeteering to get eyeblinks? When I export the guy the same way as I did in CT4, there's no eyeblinking. I'd rather have the option of auto eye-blinking, but I can't figure out how -- thanks!
lee
By Popeye - 18 Years Ago
Hi lee
When in the preview just click with your mouse on the screen and the character blinks. This will also work while you are recording. Hope this makes sense!!!
By lungemach - 17 Years Ago
Related to this subject of eye blinking, for me the eye blinks at the proper rate when recording, however, when I play it back it shuts and remains shut for about one to two seconds and opens very slow. This seems to happen when using other head motions. What's the secret to get a normal eye blink?   Another Lee
By Cricky - 17 Years Ago
Suggested fix(es):
You may want to try increasing your frame rate on export...30 fps is better than 15 fps. It may be the video refresh isn't keeping up also...tweak it on the nose and see if there may be a problem there. Most of the time it's a memory problem and video rate that can cause this.
You do realize this is in the old BETA test posting area, right?
