I have problem to get Gensis to Iclone Character transfer with iCloneFaceKey,duf etc working!
Home
Archive
iClone 6 Forum
General
https://forum.reallusion.com/Topic318840.aspx
Print Topic
Close Window
By alfhak
8 Years Ago
Hi!
Today I tried to use the iCloneFaceKey.duf working so I could transfer a DAZ Genesis character
into 3DXchange but don't know if it is me who don't understand how to do it or there is some error
with the program I have! I have DAZ studio Pro 4.6 and 3DXchange 6.42 Pro!
There is a document "DAZ Genesis Face Key Sequence" I try to follow but it does not work for me!
Then I double click on iCloneFaceKey.duf file DAZ open and a error message:
An error occurred while reading the file, see the log file for more details!
I tried to find the log file but can't find it! DAZ installs files at different place on my pc!
I have main program on E: drive!
On my timeline in DAZ, I can't find any iClone face Key sequence mention in the document
for the conversion work flow!
If I try to Export from DAZ to a FBX file I don't get up a window named FBX Option either!
I can export it from DAZ direct to an FBX file!
I really hope someone can help me and I also hope you understand
what I am asking for!
Thanks in advance!
Alf
By TheOldBuffer
8 Years Ago
Select the head in Daz then drag and drop the duf key onto it.
By JimmyB7
8 Years Ago
The only DAZ version I have found that works correctly every time is DAZ Studio 4.9.3.166 Pro (64-bit) Public Build +Beta+
By alfhak
8 Years Ago
TheOldBuffer (3/7/2017)
Thanks Tutor!
That helped!
Alf
By mark
8 Years Ago
Yes the folks here helped me with a similar problem. DAZ 4.9.3.166 PRO seems to work fine.
By Genursus
8 Years Ago
I just upgraded to the newest version of DAZ3d 4.9.4.122 Public Beta and now none of the Genesis Facekeys are working anymore when I import them to 3dXchange 7. They did work before (including Genesis 3), so I assume that I was using DAZ Studio 4.9.3.166 Pro (64-bit) Public Build +Beta+ at that point.
Is there a fix to this or do I have to revert back to Daz3d 4.9.3.166 (if that's possible)?
By dogged2003
8 Years Ago
Genursus (8/13/2017)
Also looking for a solution, and did not find another.
https://forum.reallusion.com/338105/Daz3d-Genesis-Facekey-DUF-not-working
By Genursus
8 Years Ago
I regret upgrading DAZ as I never did figure out how to revert to an earlier working version for 3dXchange. It seems it's not possible. A fix would be nice.
