Intel user minimum system requirements
https://forum.reallusion.com/Topic317556.aspx
Print Topic | Close Window
By salihtmajeedgis - 9 Years Ago
I am using  a intel i5 ...and windows 10 64 bit os. Which iclone is best for me....if any 😔.
By justaviking - 9 Years Ago
Your CPU and Windows are fine.
Do you have a separate graphics card, or only the Intel (part of the CPU) graphics?
By Rampa - 9 Years Ago
There is really only one iClone starting with version 7. It is the "Pro" version. What will still differ is the version of 3DXchange , if your getting that. Unless you need to export iClone characters and animation out a game engine, or something, you should get the "Pro" version. Pro gives you all the import and bone re-assigning tools.
As JVK mentioned, you need a separate graphics card. If your buying a new card, I would suggest the Nvidia GTX 1060/6 gig as a starting point. You want a lot of VRAM on the card for iClone.
thank you for a quick reply!!
yes. I have only the intel i5(part of cpu). is it possible to run iClone6 Pro or 3DXchange Pro without a separate graphics card.
