To add new studf creation in create menu in clone
https://forum.reallusion.com/Topic316172.aspx
Print Topic | Close Window
By drirfanmurtaza - 9 Years Ago
I have a question, is there way to add new material or stuff while creating 3d with clone.
For example in the menu i have an option to add / create material like sky, cave, floor etc.
Now if i want to add some more pre formed stuff like say galaxy, store front, stars, for architexture like  saw, or like stuff,
Thanks
By Lord Ashes - 9 Years Ago
I don't believe that you can do that through the Menu but that is what the Content tab is for. Under the Content tab you have sub-tabs of Project, Actor, Animation, Stage, Set, Media, Package. All these have sub sections which basically resolve to folders on your computer. As such you can add sub-folders to create whatever hierarchy you want. You can put any iClone content in these folders although they have to be in the correct main folder (e.g. if you put Props under Actor or vice versa you want see them in iClone). If you import content you can then save it using the "+" button on the Content tab. Similarly if you create content within iClone you can save it using the "+" button.
