exclude Bodyparts from Motion ?
https://forum.reallusion.com/Topic315952.aspx
Print Topic | Close Window
By vidi - 9 Years Ago
if I use e.g a walk animation , I can not find a Opption that excluded the arms .
I want a Character Walk and hold a Item .The Arms an Hands are moving , but it should not
By kylelee - 9 Years Ago
You can try "Remove Motion" for your Character following steps.
1.) Select your character.
2.) Open the Timeline.
3.) The select motion then right clicks.
4.) Remove Motions that you do not want.
https://forum.reallusion.com/uploads/images/365a50c0-b94a-4161-bd3a-a86f.png
Strange,  that is what I use but without a effect , The Arms are still moving :blink:
By Ola(RL) - 9 Years Ago
Hi Vidi
This is a great report.
We found a small bug based your feedback.
As you remove motion, the motions on shoulder and hand will be removed but the elbow motion remains.
This is probably why you character's hand still moves after remove motion.
We will fix this ASAP.
Meanwhile, you can send us your project to help us identify if the problem you encountered is what we identified.
You can sent your project to olawang@reallusion.com if it is available.
