Uvs missing
https://forum.reallusion.com/Topic315676.aspx
Print Topic | Close Window
By evidanse - 9 Years Ago
Hi everybody !
I am creating clothes for iclone 6.5 with the indicated procedures, using marvelous designer . And everything works fine except when I want to use the uvs via photoshop for the opacity map or the weight map; Photoshop does not launch when I click  the buttons; Nevertheless my uvs are present in maya..or 3ds max and my model is imported without problem in character creator.
can anyone help me ?
By wires - 9 Years Ago
Have you set the path to Photoshop in the Preferences panels of iClone and CC?
https://forum.reallusion.com/uploads/images/f90cb337-9f42-48a5-96f1-2996.png
Yes, i usually use photoshop to modify excisting clothes in cc
By animagic - 9 Years Ago
evidanse (2/10/2017)
What Gerry means is, did you actually set the path to Photoshop in the preferences as indicated in his screenshot? That will determine what graphics editor will be launched.
EDIT: There have been instances where you need to run iClone as administrator in order for the setting to "stick".
hello animagic.
I set the good path to prhotoshop in the preferences. I can launch it when I use the official template clothes, but not when I use mine....
In maya the uv editor is correct .  I apply a texture to the cloth, skin it to my character, copy wkin weight, and export in fbx file.
In Character creaor evrything works fine , good diffuse texture, and I can use the uv setting panel.
The only thing I can not do, is editing the uv references via photoshop...
Thank you
OK, I think I understand what you are trying to do. The UV references within iClone and CC are fixed and cannot be edited from within the application.
Hello
I bought some new clothes in the marketplace and I managed to open the uv map in photoshop which is very useful for weight map editing.
I don't know why I can not open this file...
I noticed that when i import my clothes as a prop into iclone, I can open the uvs, but not when I import them include in the fbx file via character creator.
animagic (2017-02-11)
I don't want to edit the uvs but use them for good creation of the diffuse, opacity, weight maps...etc...
