CC crashes
https://forum.reallusion.com/Topic315534.aspx
Print Topic | Close Window
By hmadden - 9 Years Ago
CC crashes a lot what am I missing? win 10
By animagic - 9 Years Ago
What are your system specs? Is this CC 1.5 or CC 2.0? Personally, I have no stability problems, so we need some more information.
By Snarp Farkle - 9 Years Ago
hmadden (2/8/2017)
Hi hmadden,
I've had a couple crashes with CC also, I suggest that you send your CC dump files to support so they can look into what's causing it on your machine.  If you use the example from my post on CTA3 crash reports found [HERE] it will speed up the process of getting an answer from them.
