Problems with Nose
https://forum.reallusion.com/Topic315518.aspx
Print Topic | Close Window
By silvioaugustojr - 9 Years Ago
Hi everyone,
Thank you for all your attention.
I am trying to figure out how to fix the nose of my avatar. You can see that there is 2 spots below the nose, which actually have to be a little bit more up...
Someone could please help me?
Thank you!
By Snarp Farkle - 9 Years Ago
silvioaugustojr (2/8/2017)
Hi everyone,
I tried select the red dot lower, but the problem still the same...
Thank you!
Hi silvioaugustojr,
I very seldom ever have to fool with the nose points other than making sure that I place the nose tip marker in the right place, if it looks odd I just go back and move it a little to get the right spot then I leave it alone because you could spend days trying to get it right.  Instead I found it's much easier to play with the nose settings in the "Detailed Morph" pane and then final touch-ups in Character Creator.  Also the lighting in CT8 is different than CC or iClone which will play tricks on your eyes.
https://forum.reallusion.com/uploads/images/3dbe051a-2b64-4834-81c2-fae5.png
Thank you Snarp Farkle,
I have to say that I did this a lot, tried every available in the ruler function, unfortunately I dont know why this keep like this.
I understand that for some unknown reason the nose is not dimensional as it should be...
Can you imagine why this is happen with this particular image?
https://forum.reallusion.com/uploads/images/83e167d7-6aa9-4f8f-b2dc-6bbf.png
Here I am trying another image, and again the same problem, this time just in one nostril...
https://forum.reallusion.com/uploads/images/07c55230-c768-42f7-b951-6e69.png
By pmaina - 9 Years Ago
Its worse when combined with side fitting. Anything you fix on the side messes up the adjustments you had made in the front. Totally Bonkers & time wasting.
By animagic - 9 Years Ago
pmaina (2/16/2017)
Not if you know what you are doing...
By justaviking - 9 Years Ago
animagic (2/18/2017)
pmaina (2/16/2017)
It's tricky, and I'm not very good at it.  Usually I am handicapped by lack of good photographs suitable for face-fitting (in addition to my lack of skill).  I almost always seem to struggle with the border of the eyelids, so I know how you feel.  Sometimes I have problems with the nose like you did, but usually not too bad, though I might have to start over and try again.  However, I've seen other people (real, mere-mortal people) share some very good results.  Practice makes perfect.  :)
By sjonesdc - 9 Years Ago
silvioaugustojr (2/10/2017)
It looks like the the right outline is not out far enough.  You will need to make some adjustments with any of the face fitting.
https://forum.reallusion.com/uploads/images/28008540-3788-436d-8283-529b.png
@silvioaugustojr
I copied your pic from the forum to see if I could reproduce your findings, the first thing I did was straighten the photo to a more suitable angle in paintdotnet.
Then took it into CT8 to give it a whirl and found the same as you with the nose.
https://forum.reallusion.com/uploads/images/97f06a2e-f111-45bd-9b4c-936e.png
I rarely mess with the nose like I said however this one had me stumped, but I found that trying the other facial settings in Face Profile page will sometimes fix some problems...
https://forum.reallusion.com/uploads/images/9c248402-2e48-4447-8ec6-8797.png
Now this guy isn't Asian I don't think but the nose lined up so I used it then made some adjustments in the Detailed Morph section not the front or side panels.
https://forum.reallusion.com/uploads/images/a7855843-936b-4a0b-8106-e8fb.png
Once I accepted it and it came into CT8 I just sent it to CC to see the results and pulled the face out a little to get rid of the Asian qualities and give him CC eyes and had to adjust those as well but didn't spend a whole lot of time on it, still needs work but looks pretty close.
https://forum.reallusion.com/uploads/images/239d0301-af88-4ddf-8f9d-c347.png
I've found that getting the photo as straight as possible usually corrects some things, I always do this first and make a template in PaintDotNet like this to align things a little.  Also if I'm having problems with a pic I sometimes copy the better half of the photo and flip it horizontal to give me a better pic to start from.
https://forum.reallusion.com/uploads/images/650444d5-68ea-47cb-95fe-7f12.png
https://forum.reallusion.com/uploads/images/93f83d04-7a80-47e1-b88f-7868.png
Hope this helps.
