By jolife - 8 Years Ago
Hi, I'm rendering a sequence (about 400 frames) in Indigo with GPU Acceleration on. It renders okay in the first frame but in the fallowing frames the GPU Acceleration option switch off. Why is that? Is there an option to "freeze" GPU Acceleration for all the sequence? Any help, please?
Many thanks!
By TheOldBuffer - 8 Years Ago
In the Indigo Prefs panel in iClone, select GPU acceleration at the bottom of the pane. It should then have gpu acceleration on all frames.
edit. You will have to re-export from iClone to implement the gpu acceleration mode.
