Disable shadows
https://forum.reallusion.com/Topic312156.aspx
Print Topic | Close Window
By jolife - 9 Years Ago
Hi,
I
m using iClone 6 and Indigo as a render engine.
I would like to know how to disable the cast shadow on my character.
Thank you!
https://forum.reallusion.com/uploads/images/bcf0dbe8-a7e0-473e-bf82-fe8e.png
By Zeronimo - 9 Years Ago
hi Jolife,
1 in the SCENE tab
2 select your character in the avatar list and click the fourth icon
3 chooses the option that suits you
https://forum.reallusion.com/uploads/images/ec5b403b-d498-4890-8f28-5f55.jpg
Hi zeronimo,
I tried your method but it continues to render the shadow. I disabled the key light shadows but doesn't work either.
Should I change any lighting settings in Indigo?
Thanks for your help!
https://forum.reallusion.com/uploads/images/5cf7d7b4-d877-44e3-8ea8-0aa0.png
https://forum.reallusion.com/uploads/images/e8c4dd13-6484-4257-a450-0a06.png
By animagic - 9 Years Ago
I haven't used Indigo in a while, but it has a different lighting system from iClone. For example, if you use the built-in sunshine setting in Indigo, you may get a shadow.
