Importing OBJ sequence into iClone?
https://forum.reallusion.com/Topic312079.aspx
Print Topic | Close Window
By eternityblue - 8 Years Ago
Is this possible? Of course I mean through 3DXchange.
One key thing is the OBJ sequence doesn't have the same poly count in each frame, I am looking to bring fluid simulation from Blender into iClone.
By animagic - 8 Years Ago
It is currently not possible, but it would be great.
DAZ Carrara has an object sequence importer. I've played with it, years ago. I had a group of columns being smashed in Houdini and could export the simulation as object sequence.
EDIT: Alembic import would probably give you the same, easier.
Yeah,  it is probably better to ask for Alembic support,  I just wanted to make sure I wasn't missing anything. I also have seen obj sequence used for particle emissions, so maybe that would be possible. I wonder if they are working on updating the particle system,  or if a third party will do that via the api.
By wendyluvscatz - 8 Years Ago
I think Alembic needs to maintain vertex count too.
painful as it is you can just import all the obj then toggle visibility along the timeline, opacity sliding probably would transition better.
By planetstardragon - 8 Years Ago
technically it is possible in an unorthodox way -
basically take your base obj model,  add a standard human rig / bone to it,  do the basic rigging set up in 3D exchange,  the morphing section becomes active.......then import the animation shapes as morphs. - obviously not practical for an extended sequence,  but all the same possible.
There's always a way to do something in iclone,  you just have to be creative about it, the fundamental tools of doing a whole lot of things is there.
planetstardragon (1/12/2017)
eternityblue (1/11/2017)
yes the vertex order issue or I too would have suggested that
I run into the same problem styling LAMH
By GOETZIWOOD STUDIOS - 8 Years Ago
wendyluvscatz (1/12/2017)
I think Alembic needs to maintain vertex count too../..
Nope, vertex count, topology, type of geometry, attributes, etc.. can change at each frame.
So,  right now,  I'm away from Blender,  but I'm thinking of trying to shrink wrap a fluid sim and see what happens. Does the shrink wrap always keep vertex order? It seems a way of getting a fluid Sim simulated as a shape key morph would get me closer than anything at this point.  Ideas?
I have never tried it but if like dynamic cloth it should and sounds brilliant if its doable
Regarding fluid,  I did get the ocean sim output to Blender and can animate that,  so maybe a combo of things together will give a reasonable result. I don't know exactly what I even want to use it for,  but anyhow, it's a puzzle.
