By eternityblue - 10 Years Ago
I hope you like it, the hair is bad but maybe a little love in CC would make it better, I dunno. I went with just using the mesh for everything to give me the freedom to unify the hair.
http://city.reallusion.com/ContentPreview.aspx?i=JCC1cff14019028358b6&g=
This is also meant to be stylized, so apologies in advance if the hair doesn't do it for you, I'm going with mesh for hair so I can use DOF without transparency issues, and wait for iClone's hair system to get to the point of doing fur. It saves on polygons too.
By Space 3D - 10 Years Ago
Looks cool . This hair as cloth or accesories or morph head. You make a lot of idea of character creator.
Visit Space 3D Gallery - http://city.reallusion.com/store/space3D
It's actually Delerna that gave me the clue in. That and it is an old fashioned way when things were much more basic. For myself, it is a good compromise and I can try and mix in the regular hair when it will look OK. Just I love me that dof so this was a big boon for me.
Oh, it is a morph head, so you can also make a morph dial out of it. I'll post the beard with transparency later so anyone can apply the beard and create bump and spec maps themselves, otherwise you can't adjust it much without something looking kinda horrible. And it could be used as a map for creating new hair from scratch. I'm on a phone, IL try and get to it ASAP.
BTW, Delerna has started releasing his mustaches as morphs, so check them out. You can easily use either his skin or make bump and spec maps yourself with his images as templates. This makes viseme morphing facial hair possible, as well as dealing with hairline issues with separate hair. It is a good compromise if you aren't going for realism. And the lip sync itself will always look more real.
By Snarp Farkle - 10 Years Ago
Thanks eternityblue, I'll play around with it and see what I can do. :)
