Fixed window
https://forum.reallusion.com/Topic306947.aspx
Print Topic | Close Window
By CeZikk - 10 Years Ago
Hi!
I am using two monitors. On the second monitor I always have my timeline. What bothers me is that this window is constantly changing its height. Whenever I click on some body part on my character
the program make some additional layers visible, and the timeline is getting bigger. I need to resize the height all the time so I can see it all. Any way around to fix this?
By Peter (RL) - 10 Years Ago
Try toggling off "Object Related Track" from the top left hand end of the Timeline.
This should allow you to select what you need from the Track List and maintain the height of the Timeline.
Doesn't work at all.
It will only work if you select everything from the Track Menu List first and then resize the Timeline height to show all the tracks. It should then maintain the height of the Timeline even if you close it and then reopen it. Not a prefect solution but it does help.
