Popvideo 3 Fail to render audio
https://forum.reallusion.com/Topic302860.aspx
Print Topic | Close Window
By bernnelsen - 10 Years Ago
I am having an issue with popvideo 3.01. It will not render the audio portion of the video. The video was exported from CTA 3 and the audio plays fine in Ppovideo preview but it does not render in any of the 3 formats and I have the mute audio unchecked.. Any help would be greatly appreciated.
By Peter (RL) - 10 Years Ago
Have you tried exporting from CTA3 using a different video format (avi, wmv etc.). If so does it still lose audio on convert to popVideo format?
I tried exporting in all formats. I tried the alpha with and without sound as well as all the available formats twice with the export sound checked and unchecked.
Thank you for the reply
bernnelsen (12/8/2016)
If the problem is continuing, please contact our Technical Support department using the link below. They will be able to help you get this resolved.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
By dimke.b - 10 Years Ago
Same problem. No sound after render
Please see my previous answer and contact Technical Support. They will try to help you resolve the problem. :)
By Jeremy_Lawrence - 8 Years Ago
Did you get this resolved?  I've just encountered the same.  The popvideo file renders properly in iClone 6 but renders mute in iClone 7
