Iclone Lipsyncing to Daz?
https://forum.reallusion.com/Topic302828.aspx
Print Topic | Close Window
By Rich_Crystal - 10 Years Ago
After going through the pipeline tutorial on exporting/importing a Daz character into iclone 6 I animated a character in iclone 6 with lip-syncing and I am trying to export this back into Daz. The BVH file I exported from 3DXchange doesn't seem to have the lip-sync animations but does have the body animations. Does anybody have a tutorial on this process?
By animagic - 10 Years Ago
You would need to export as FBX, but from what I have heard FBX import into DAZ is problematic.
Make sure to export from iClone as MotionPlus in order to see the facial animation.
EDIT: sw00000p was 1 millisecond quicker...
sw00000p -
You actually imported an ic6 character (FBX) into Daz?
...according to rampa, Daz doesn't import (fbx)....only (bvh).
Re: (BVH).... You must make sure the iclone "bvh Profile" match's Daz's "bvh Profile"
animagic -
Thanks for the reply sw00000p and animagic. I have tried exporting FBX and BVH files from 3dXchange into DAZ, both are problematic. With the FBX file the character comes in morphed and is unrecognizable. With the BVH file I matched the iclone BVH profile to the Daz character profile and the character animation comes in perfect except for the lip-sync keyframes. The body movements are there but the mouth movements are not? Any ideas?
