CrazyTalk Animator 3 Known Issues & New Report Method
https://forum.reallusion.com/Topic301550.aspx
Print Topic | Close Window
By Ola(RL) - 10 Years Ago
Dear All
You will find currently known issues of CrazyTalk Animator 3 in the FEEDBACK TRACKER of Reallusion.
Feedback Tracker will help you to track the fix status of the issue you reported.
Bug reporting format, please check HERE.
**How to report bug through Feedback Tracker:
1. Go to Feedback Tracker and click NEW on the up-right corner:
https://forum.reallusion.com/uploads/images/0892bf34-9348-4c0e-a4ad-251c.jpg
2.Login with Reallusion account:
https://forum.reallusion.com/uploads/images/f583d955-2130-4468-8bc2-69ed.jpg
3.Select CrazyTalk Animator 3:
https://forum.reallusion.com/uploads/images/d302ff4a-9103-435e-b173-b86e.png
4.Report issue.
For more details, please refer HERE.
By post_76 - 10 Years Ago
Wishful feature : it would be really nice to have either a "sprite switch all" or "drop to switch character" on g3 characters. that way it could be possible to simulate having a 3-angle (maybe 6 of you could mirror the animation supporting a character seen from behind) character in g3.
Right now, I design two characters and minutely place the side view the exact same place as the front view, then disable one and enable the other.
Wishful feature : if I add a piece of media on frame 200, then it should not be visible from frame 1-199. that way I save the hassle of rewinding and turn off visibility.
In most cases, it's intuitive to add assets when needed and not everything from first frame.
Wishful feature : (not sure if this is already possible) save poses. when I have made a pose (not an entire animation or loop),  or would be nice to be able to reuse it. maybe it's just saving a single frame? well..  a separate area for poses could be nice.
By AverageJoe - 10 Years Ago
post_76 (11/13/2016)
This is not how traditional animation works.  I would rather CTA conform and keep with how standard animation application work than trying to force new workflow ideas on people.  I suppose if it could be added as an option, it would be ok, but I want to maintain full control over my timeline.
wizaerd (11/13/2016)
This would not "remove" the animation form timeline, but just turn off visibility on frames before the one, where you add the character.
I really can't see how it is good, that every asset pops into existence on frame 1 ALWAYS. Can you illuminate me on just 1 use case, where this is wishful? Just because "this is the way we always did", doesn't make it smart.
"Traditional animation" includes stop motion - where assets are ONLY present on the frames needed. So unless you can argument why, I simply don't get your point :o
Regards
