Character Creator 1.51 Scale Down 30% Model Broken
https://forum.reallusion.com/Topic296873.aspx
Print Topic | Close Window
By Space 3D - 10 Years Ago
Dear iCloner ,
I use character creator version 1.51 model , then use scale down until to be baby model ( Turn down 30 % from CC default).
The result on T pose is OK NO problem , but use calibration and motion model will be broken.
This proses from 3dxchanges Pipeline 6.5 - iClone 6.51 - Character Creator 1.51  ( Model replace by obj mesh )
Please , any solution for this case.
What compactible Obj file for Character Creator 1.51 ?
I use scale down with Obj file on Character Creator 1.4 -----------> No problem ( Model result good with motion )
https://forum.reallusion.com/uploads/images/259bd180-0917-4059-a22d-0f50.png
https://forum.reallusion.com/uploads/images/3bf32054-6ba7-4113-a333-16a8.jpg
By Rampa - 10 Years Ago
Looks like you scaled the mesh but not the bones. Replacing the OBJ will only work if the body is the same proportions/scale.
It'll work if you scale the skeleton as well, and import it as a morph into CC.
By hj - 10 Years Ago
There is no problem scaling a character in CC 1.51
https://forum.reallusion.com/uploads/images/6b59025b-a03c-4599-b3c2-129f.pnghttps://forum.reallusion.com/uploads/images/04137a4b-9504-490f-829e-2b9a.png
best hj
