Cleaning up Mocap data
Home
Archive
iClone 6 Forum
General
https://forum.reallusion.com/Topic295189.aspx
Print Topic
Close Window
By Mr. Perfect
10 Years Ago
Hello Folks! Since I cannot find any answer here on the Forum, I just start this new Topic.
I was wondering if there is an easy way to clean up the jitter of Motion files, like shaky feet and stuff like that. Is there any Software around that could help? I found a tutorial on you tube that helps a Little bit, shrinking the Clip an then stretching it again, but that is not really an optimal solution. I own the Axis Pro Mocap Software, but hadn't time to check if it's possible in there. I just want to find some Information before starting creating Motion files with my Percepition Suite. I have watched a lot of Tutorials about it, but nothing about noisy files. Any help would be appreciated. :-)
By davood.kharmanzar
10 Years Ago
the pro method is retargeting ...
you can use
IKinema Action for MotionBuilder ...
http://www.ikinema.com/index.php?mod=forum&forum=8
By Mr. Perfect
10 Years Ago
Thank you! :-) But isn't that for use with another program than iClone?
By mtakerkart
10 Years Ago
I started a topic about the Neuron mocap and there's a little tutorial I made for that:
https://forum.reallusion.com/FindPost295145.aspx
By Mr. Perfect
10 Years Ago
mtakerkart (8/30/2016)
Thank you! I really like your Topic! :-)
By Lamias
10 Years Ago
For motion capture with Kinect, is it possible to clean the jitter and the shaky limbs? I always get shaky legs/arms, and i don't know how to smooth them.
Will retargeting solve this? Should i look for tutorials?
