There are a couple of minor issues with the freebie. I added a transform key to the veil (by accident) when I was resizing it, so you may notice as it plays on the timeline, it changes size. You can either delete one of the transform keys and save it again or you can download it HERE.Also, when you apply the upper skin material, if you are using violet as a base, the upper skin will be dark and the character will remain light. To fix this,
1) Apply the upper skin texture;
2) Change to the Head Skin Texture in the drop down menu;
3) Check the box "Effect All Materials"
4) Now select a skin tone for your character and it will match her whole body up.
Thanks Cricky for pointing out these issues. :)
