Exporting Accessory from Blender?
https://forum.reallusion.com/Topic294546.aspx
Print Topic | Close Window
By Lordhi - 10 Years Ago
This tutorial shows how to create and export accessory from Maya to Character Creator: Character Creator 1.5 Tutorial - Accessory Creation .
I tried to do the same with Blender. I imported an object from DAZ and parented it to the head bone. However, when I export the avatar as fbx without weight painting, Character Creator crashes when importing. When I weight paint as doing with clothing, Character Creator declares the object as "hair", not as "accessory". What am I doing wrong or which step(s) am I missing? (I do not own 3dExchange Pipeline and use the Body templates provided by Reallusion.) Any advice would be much appreciated.
Jürgen
https://forum.reallusion.com/uploads/images/4872538b-a28b-47db-a2f8-6c9a.jpg
By wires - 10 Years Ago
Just import the object into 3DXchange Pro - you don't need the Pipeline version - and save it as an iProp. In iClone attach the iProp to a character bone, adjust the position, size and rotation and it will automatically be converted to an iAccessory that you can save in your custom folder.
... And you can copy the file to the Accessory custom folder in Character Creator and rename the ending from .iAcc to .ccAcc. Then the former Prop also works in Character Creator, if you wish so.
Thank you very much, Gerry, this is a very nice and easy solution!
