By steve_20140811193313686 - 10 Years Ago
Is the IClone Allegorithmic Substance Designer the same as they sell on Allegorithmic site because i have that or is this embedded into Iclone version?
Thanks
By justaviking - 10 Years Ago
The "Allegorithmic" Substance Designer will work fine. You will need to map the outputs to Diffuse/Specular (not metallic) channels because iClone does not support a PBR shader yet.
