"unsaved project data found" error on every luanch?
https://forum.reallusion.com/Topic293329.aspx
Print Topic | Close Window
By jamie3d - 10 Years Ago
hi every time i run character creator i get this error message "unsaved project data found"
i then have to save a restore file.
I'm on windows 10 and running cc 1.51.2001.1
any ideas, how to resolve?
thanks
By wires - 10 Years Ago
There should be an option to cancel/ignore the data, doing that "should" solve the problem.
You could also look in the Preferences settings to see where the Temp data files are stored. Go to that folder - with Character Creator closed - and delete any files that you find, that should also solve the problem.
If the above don't solve the problem then you should uninstall and reinstall CC, also making sure to delete the CC Temp folder before reinstalling - if it still exists.
Thank you, deleting all the rubbish in the temp folder fixed it.
Happy to help. :):smooooth:
By raid_90 - 9 Years Ago
I have the same problem, how can i find this option?
