Neuron Mocap Plug-in Issues and Suggestions Thread
https://forum.reallusion.com/Topic293299.aspx
Print Topic | Close Window
By Melanie (RL) - 9 Years Ago
Dear Developers,  Please post bugs and issues you have encountered while using IC 6.5 Beta.  All reports will be summarized here.
By Beat_CH - 9 Years Ago
Hi Melanie,
Question to Axis Neuron Version:
It works fine with:
Axis Neuron 3.6.32.3903 and iClone 6.51.3127.1.
It doesn't work with the Axis Neuron (Pro-Version): 3.7.42.5837.
Is there a chance to get the Plug-in working with the Axis Neuron Pro-Version?
Regards
Beat
By luke (RL) - 9 Years Ago
Hi, Beat_CH
Do you check your server port in Axis Neuron is the same as iClone ?
https://forum.reallusion.com/uploads/images/0007b175-32b0-42d8-b220-8ce1.png
https://forum.reallusion.com/uploads/images/80fb9665-e533-41cd-9703-fde8.png
Beat_CH (8/8/2016)
Hi Melanie,
It works fine with:
Regards
Beat
Hi waveact,
Thanks for your hint.
The ports were ok.
I just reinstalled Axis Neuron 3.7. and it worked fine.
Regards
Beat
By davood.kharmanzar - 9 Years Ago
By gareth_15 - 9 Years Ago
Hi Guys
Does any one have any idea why the live Neuron duo plugin crashes as soon as you click on it?
I can see the plugin but it has no option to select single or Duo??
I'm using Newly installed
Iclone 6.51.3127.1-  Pro
Axis Neuron 3.6.32.3944
As soon as I go to press on plugins/perception neuron/perception neuron duo it crashes?
Any one, Bulla?
Hi Beat
Where did you find this plugin
Axis Neuron 3.7????
I can only find 3.6
Gareth
all fixed, reinstalled all again
seemed to work, maybe plugin had partial download
very very powerful stuff
Gareth
www.luxastudio.com
By ninjarama - 9 Years Ago
Can you explain how you got it to work?  I have the exact same issue... I clicked on the plugin from the menu (as shown in your .gif image) and it instantly crashes iClone.  Thanks!
By anthony.ur - 9 Years Ago
Every time I launch the Mocap Plugin, and select preview the software instantly crashes.  OS is Windows 10, latest Nvidia Driver, GTX 765m, Latest version of Axis Neuron Pro, latest Iclone 6.52 Latest Neuron Plugin 1.1.  I am pulling my hair out with this trying to resolve the technical issue.  I have already uninstalled and reinstalled both.  Brand new user to iClone and I am not happy thus far.
https://forum.reallusion.com/uploads/images/fa11084f-e35a-4ecf-b098-ecab.pnghttps://forum.reallusion.com/uploads/images/7898e06d-e955-412a-9432-2c82.png
howto matching the motions of source actor of neuron mocap with the stylized iclone's character?
my biggest problem is matching the motion arms and hands of neuron actor with iclone's stylized character like as tokomotion characters ... arm and hand going into the body or face :\
is it possible to retargeting inside iclone? (like as ikinema for motionbuilder?)
By mtakerkart - 9 Years Ago
You can edit position Arms/Hand with the "Edit motion layer" Tab.
Suggestion: When performing with actors and the Neuron suit , it's helpfull to Broadcast live
inside Iclone with your stylised character. The performer can see the space limit moves to not
penetrate the character shape.
mtakerkart (12/22/2016)
it's helpfull to Broadcast live inside Iclone with your stylised character. The performer can see the space limit moves to not penetrate the character shape.
yup ... i'm just using live broadcasting ... and i'm performer :]
but it's very hard to matching me with characters :\
is it possible to define joint rotation limitations for iclone character?
I don't know for the joint limitations.
Don't forget to setup your body profil in the axis Neuron with your real body measurements, it helps.
Like in "hollywood" I suggest also  to put real props on your body to simulate the avatar size body.
The more you're accurate on reccord the more you save time in edition.
Yes motion capture  take practice performance for fast/good result ;)
By ninjarama - 8 Years Ago
I don't know at what point the Perception Neuron Plug-in was fixed, but things are working now (with the pro version of Axis)!! I did download the latest version of the plugin from my reallusion account and I also updated the firmware on each of the neuron sensor so I'm not sure if any of that had to do with it as well.
The main problem now is with the mocap sensors and calibration inside Axis software... so janky, especially with the feet and the fingers.  No matter how many times I run the calibration, fingers are curling and feet are like pigeon toes!  Nothing to do with iClone though...
I'm glad the plugin doesn't crash anymore!  Hopefully it all still works with iClone 7 =)
By hoaphamkhanh - 8 Years Ago
I used the Neuron Plugin-trial and iclone 7-trial.
When I installed Neuron Plugin again encountered this error? How do i connect iclone 7 with axis neuron?
https://forum.reallusion.com/uploads/images/72e789b1-7a23-415a-9399-b0cf.jpg
