What's New in iClone 6.51
https://forum.reallusion.com/Topic292579.aspx
Print Topic | Close Window
By Melanie (RL) - 10 Years Ago
Hi Everyone,
Here are a list of important bug fixes we have included with iClone v6.51
iClone 6.51 (6.51.3127.1):
Fixed: The appearance of on-screen watermark for purchased content after executing some commands such as Undo, Delete, etc. Feedback Tracker Report
3DXchange 6.51 (v.6.51.1927.1):
Fixed: "Not enough Memory" error message when importing FBX files. Feedback Tracker Report
Fixed: Shared texture reference broken after importing FBX to 3DXChange. The duplicated textures increase the file size drastically.
To learn more about iClone 6.5, please visit:
http://www.reallusion.com/iclone/iclone_whatsnew_visual.aspx
Thanks!
Melanie
By wires - 10 Years Ago
Wondeful news Melanie. :cool: Thank you, and the dev. team,  very much. :)
By BiggsTrek - 10 Years Ago
Thank you!
By Atonnis - 10 Years Ago
Awesome stuff, Melanie!  Thanks to the whole team!
By sidroy - 10 Years Ago
Thank you.
By rgreenidge - 10 Years Ago
Thanks that was fast, I thought you guys were going to have a problem duplicating it. When working with iClone last night. The watermarks popped up again.  I had to reboot project.
By mort3z437 - 10 Years Ago
hi max Video export duration just 13 Minute(iclone 6.5) whay?
iclone pro 6.5 not supported Indigo Render Plug-in whay???
By Peter (RL) - 10 Years Ago
mort3z437 (7/31/2016)
The maximum project length in iClone is 15 minutes or 54,000 frames. That has always been the case. You will normally work in iClone  as they do in real world filmmaking and that is to build your movie in a series of scenes with each scene being a separate project. This keeps your project sizes at a manageable size.
iClone 6 does indeed support Indigo RT with the Indigo Plugin.
If you are having problems with Indigo RT, please explain in more detail about the issues you are having and we will try to help.
By animagic - 10 Years Ago
Peter (RL) (8/2/2016)
As mentioned in another thread though, you can only enter "9999" as the maximum. You then need to click up to "10000" and then you can highlight the five digits and enter the maximum.
By xalidfetah - 10 Years Ago
Hello,
Why stil have no follow cam in iClone 6?
xalidfetah (8/2/2016)
Hello,
I guess it's not a high priority. You could add a request in the Feedback Tracker.
yes i know, but i need follow cam withaout animation
By Skuzzlebutt - 10 Years Ago
doing it manually seems to be bugged with CC, you cant just select bone root from left anymore.
so add a camera and go to the linkage section (right)
click on the the avatar's head,
then hit the 3 dots in linkage and select boneroot
now the camera will follow the actor without excessive extra movements from being linked to a moving bone
Like this cam
https://www.reallusion.com/iclone/help/iclone5/PRO/10_Scene/Camera/The_Follow_Camera.htm
Hello
How to create beard for Character Creator?
http://i.giphy.com/3o6ZtleM4XXt3w87jG.gif
You say What is New in iClone 6.51
But you do not say What is missing in iClone 6 - 6.51
You can look iClone 5, then you know what's missing
By R.Man - 10 Years Ago
When i export my 1600 frames scene  for indigo it generates 70 Gigas of extra files. 70gigas!!!! so i guess if i make a few minutes of movie my HD will be full...is there any plan for Reallusion to optimise this long export process + HD killing ? Or Is there any plan to replace the indigo renderer plug in? This feature has been over promoted  but now it's has no real improvement and seem going slowly and quietly in sleep mode. I've used Reallusion products for some years with much hapiness but i think that this Indigo episode is the most noticeable failure up to date.
manran (9/29/2016)
I'm impressed that you could even accomplish this without crashing! I have also been disappointed with Indigo with respect to animation. The topic has been discussed many times, and I believe there is an entry in the Feedback Tracker. Not much reaction from RL thus far.
By justaviking - 10 Years Ago
animagic (9/29/2016)
manran (9/29/2016)
Here is an Issue I posted on Feedback Tracker related to the massive quantity of data exported (and the time it takes to do so):
http://www.reallusion.com/FeedBackTracker/Issue/Make-Indigo-multi-frame-export-more-efficient-by-using-a-single-copy-of-things-that-don-t-change
By hattori kun - 10 Years Ago
manran (9/29/2016)
I'm still hoping they adress this. Indigo is a pretty good renderer.  The export process is killing the experience. That's on RL to fix.
By yoyomaster - 10 Years Ago
For what its worth, and with 6.5 having Alembic export, I gave up on Indigo and just export the whole thing to .abc files and import into Blender, there I only need to drop pre-made textures on the different parts of the model, set the lights and camera, and render with Cycles, I also get the benefit of having everything that comes with Blender, such as good particles, embedded copositor and so on!
For the time it takes to export to indigo files, I have plenty of time to setup my scene in Blender, heck, you could setup an Indigo render from inside Blender if you wish, since Indigo supports it!
Well they are still selling iclone indigo and the users that did pay for it still needs to get the issue fixed.
hattori kun (10/13/2016)
Absolutely, only proposing a viable solution until they do!
