By Skuzzlebutt - 10 Years Ago
this requires 3ds max, but it has good tips common to all 3d apps. and should get anyone converting like a boss. it also includes calibration poses so there isnt much work in your 3d app lining things up. it is a beginner level tutorial so someone who never used these programs can follow along (using pause) there is also a calibration pose that is common to OBJ charactor models so you can chop off parts and convert them quickly as well. (link at bottom of post) duration: around 7 minutes difficulty: very easy
keep in mind: in your 3d app you do not need to have things 100% lined up and perfect, CC has conform and mesh editing tool to fix holes and shape the mesh.
calibration poses: http://www.mediafire.com/download/bz833cxauomse3s/calibration+poses.rar
By brand468 - 10 Years Ago
Big thanks "budbundy", this is exactly what I needed :):):)
By BOLPHUNGA - 10 Years Ago
Thanks for this works like a charm was very easy to follow even with out audio
your welcome guys,
i had tech problems, so couldnt do this with audio, also forgot to mention once you get past the erase-keyframes part to save and export(overwrite) this way you now have a template and a backup template.
By Snarp Farkle - 10 Years Ago
Thanks budbundy, I see now that it can be done but 3dmax tuts don't help me much at all, I don't own it or likely will ever own it.
If anyone knows how to do this in Blender or some other reasonably priced program, I'd appreciate some tips. :)
Snarp Farkle (7/25/2016) Thanks budbundy, I see now that it can be done but 3dmax tuts don't help me much at all, I don't own it or likely will ever own it.
look at just the beginning - exporting from daz and exporting a calibrated pose from cc. from that point it's importing the fbx in blender, then importing/merging the obj from daz you will just have to move and scale the obj and then follow the blender skinning tuts.
By redrubyslippers - 10 Years Ago
good tutorial.................
budbundy (7/25/2016)
Oh wow thanks budbundy, I was just trying to put all the steps together in my cranial grey matter, should be simple enough, I'll try it when I get home then. :)
By Anna Mironova - 10 Years Ago
thank you for tutorial:-) i have a question as i see on your video model loads in 3d max with not straight T-pose
 dress i'm exporting from daz is the same
 but mine model has straight T-pose
 so it looks like this
is there any way to fit it in the way it has to be?
annamironova2007 (7/27/2016)
thank you for tutorial:-) i have a question as i see on your video model loads in 3d max with not straight T-pose  dress i'm exporting from daz is the same  but mine model has straight T-pose  so it looks like this  is there any way to fit it in the way it has to be? yes, in the beginning of the tutorial. you export with the calibration pose provided above on import to max move timeline to frame 50 select all keyframes right click and remove selected keys move timeline slider back to frame 1 this will put the avatar into the daz pose
i quess i'm making something wrong exporting from CC like that
but it has no any keys in 3dmax http://joxi.ru/a2XK1aPiJew7mg.png
on the fbx import dialog make sure you include animation
yep its included
could it be because of old version of 3d max? i have 2010
since it's a export fbx 2012 version from CC, backwards compatibilty might be a issue. in max try "select all" from the edit menu...
with select all 1 key found :-) deliting it doesnt change anything
Oh my! got it! needed plugin fbx 2012 (took it from here http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=18817399 ) now its works!
good to hear, i was going to ask if you ever updated it...
need one more magic kick to understood where am i doing mistake.... i have made one dress with your lesson and it went well
but with this shirt i stuck. It opens in a weird way in CC where my mistake is?
not enough info. i would export the fbx from CC again with calibration erase keyframes then save as max file and export/overwrite the fbx
this will be a template and a backup template, you can add clothes export to CC. then delete skin-skin wrap and obj mesh to reset the template
seems like problem with fbx just tried to "play" wiht just a body, withour clothes and its the same weird (reexported from CC few times with the same effect) https://youtu.be/0uDIsk5cXO0
the fbx plugin may need to be re-downloaded and re-installed let me know if your still stuck and i will send you templates for male and female
reinstalled plugins works well by now (at least i was able to save templates) Tank you for your advice
lol, i just sent you some templates in PM
could you please make a calibration pose for kids (daz K4 based)
annamironova2007 (7/31/2016) could you please make a calibration pose for kids (daz K4 based)
the pose should be the same, just a different scale. so a little more work in max lining up and scaling should work.
making a pose file would require that i have a k4 fbx and a CC avatar that roughly matches dimensions.
i have tried just scale in max but it has different effect (and fbxkey doesnt suit) for models without hands position it works with just export needed figure in max, but hads position is a problem
again, i would need a fbx of the daz and CC models to make a calibration, i do not have them.:cool:
here is daz4 base fbx https://cloud.mail.ru/public/2cA9/L9TkHQ6RR but i dont know how to send it to CC :-(
and here is my CC boy https://cloud.mail.ru/public/DyyU/GKua4BiKp
i will work on these later after i finish some stuff.
after looking at these the problem is not the calibration pose. the problem is the CC shape (boy) needs to match better
to match them: i built temporary k4 accessory (download below)
load "boy" into CC and remove all clothing drag K4 accessory into cc adjust the arms legs and torso to match then delete the K4 save the cc project and export with male calibration. * the clothing item will also need to be rotated slightly before skinning
k4 accessory https://www.mediafire.com/?i2hdfeiujx5aali
i would just reshape the CC for you, but i do not own the base mesh pack
thank you i'll try
thats a weight issue
it actually was a units mismatched error our good friend "901" figured it out.
sweet.....................
