Panoramic image used in a scene in iClone?
Home
Archive
iClone 6 Forum
Training - Tutorials, Hints and Tips
https://forum.reallusion.com/Topic290752.aspx
Print Topic
Close Window
By Dragonskunk
9 Years Ago
With the panoramic feature of iClone 6.5 I was wondering...
Is there a sky sphere that has a properly setup UV map that I can use in iClone that allows a 360 panoramic view that can be viewed by a camera in the sphere?
I would love to use a custom background for scenes with large windows inside a room or a panning driving scene, or even a open cockpit biplane scene.
By Skuzzlebutt
9 Years Ago
any sky would work.
but there are a few props setup for this as well.
in props/3d space----
360 sky
dome
and tower
By Dragonskunk
9 Years Ago
Thanks!
By Rampa
9 Years Ago
Here's one you can test with.
Larger version.
https://drive.google.com/open?id=0B3nsNVGroEz6Z3pMUkt2bDNSRnc
By animagic
9 Years Ago
The 360-degree sky prop will work.
By Dragonskunk
9 Years Ago
The only problem I encountered was the texture is correctly displayed only on the outer side of the globe so if you have a scene with a store with writing on it for example then all the letters are inverted. So I had to use Blender to make a sphere and flip its UV map and made one that displayed correctly from the inside.
I included a file of a sphere prop that displays the UV maps correctly. The texture is © and not mine.
Note: I didn't set the globe texture setting Self Illumination, so you'll need to slide it to 100 to remove its shadow.
By Rampa
9 Years Ago
There are also little buttons in iClone to flip and rotate the textures as needed. They hide in the UV and tiling section.
By Dragonskunk
9 Years Ago
rampa (7/16/2016)
Oh! I see now, "Mirror H" corrects that.
Got it!
Thanks!
