Reflection problem when rendering Iclone 6
https://forum.reallusion.com/Topic290156.aspx
Print Topic | Close Window
By dgoldeng - 10 Years Ago
I have a car in my scene with three people in the car. Whwn I render the scene there is the relection of the people that appears to be coming off of the window. I've tried differen sky and lightingt settings with no results, Anyone may have a solution. Thanks
By planetstardragon - 10 Years Ago
Hello Dgoldberg,
could you please provide pictures,  possibly a video.....there are so many things that could be a factor in this,  it's hard to narrow down without more information.
for a quick check,  i'd say make sure your reflection / refraction settings are turned off -  but that is just one of several scenarios i can think of.
Cheers
note -  another quick fix I can think of is to turn off the "double sided" - "2 Sided option"   so only 1 side of the selected mesh shows - ie -  it will only reflect on the side of the normal.   ( 2 sided makes both sides visible to the camera )
By Rampa - 10 Years Ago
I'm thinking this might be because you have reflection and/or refraction on the window. Check in the materials section.
if he disables the 2 sided option,  he may be able to keep the best of both worlds though,  a ridiculously shiny windshield without the interior reflection.
