By MikeyMo - 8 Years Ago
I have a front facing character. At some point I need it to go 90 degrees. It needs to be quick. I keyframed the move inside of 3 frames. It's a good speed, but it appears awkward.
How do I smooth out the move to 90 degrees? The quickness of the move doesn't appear very natural.
CTA2
By jlittle - 8 Years Ago
Switch from 0 to 45 then to 90. If you switch from 0 to 90 directly it will be very sudden where if you put in the 45 it will look better (as if tweening).
Jeff
Thanks Jeff. Seems to be the best solution.
