By wmwdie - 10 Years Ago
Would it be possible to be able to increase the pitch of more of the english speaking voices as I'm looking for chidren's voices which naturally have a higher pitch. Only 2 seem to have that function at present and that means I'm limited to 2 children characters.
By Skuzzlebutt - 10 Years Ago
one quick way to do this without external apps is. select your avatar open your timeline select viseme from the options. select the option by the top arrow (speed) and drag the end of the waveform to the left .
By Snarp Farkle - 10 Years Ago
There's also voice changer software that will let you use your own voice, AV VoizGame is one. Look for this button :satisfied:
had a quick look. It looks good and should do the job. thanks
I'm using CTA2 and it works. Will use it the next time. Thanks
