Hi Heather,What you can do is share facial animation scripts and motion clips between the two programs.
So for example, if you create and save a talking head in Crazytalk 6 that has facial animation and spoken audio, you can then open this script in iClone4 and apply it to your avatar there.
To do this you would go to Animation - Facial Animation click the Import CTS for scripts or Import CLP for motion clips on the Modify Panel. This will then open your custom folder with your saved Crazytalk 6 scripts. You can then open these files in IC4 and they will be applied to the open avatar.
