iClone Pro 6.42 - Slider X Y Z Can Not Move
https://forum.reallusion.com/Topic286472.aspx
Print Topic | Close Window
By Space 3D - 10 Years Ago
Dear iCloner ,
Slider X Y Z can not move . ( on prop ).
Slider X and Y can not move ( manual only ).
Slider Z ( OK ) no problem .
Please , any solution for this problem . ( May be from RL officer )
This on iClone Pro 6.422728.1  ( Last Update Version )
Thank's
https://forum.reallusion.com/uploads/images/0bd29def-8951-45c0-a567-0932.jpg
By JimmyB7 - 10 Years Ago
Verified.  I have the exact same issue.
By Snarp Farkle - 10 Years Ago
Is that in "World" mode or "Local" or both?  Sometimes I found that I had to select Local to get the gismo to work.
By animagic - 10 Years Ago
I have not been able to repeat this. Both the Gizmo (World as well as Local) and manual entry work.
Snarp Farkle (6/2/2016)
Start in "Local" Transform does nothing.  Switch to "World" appears to work as advertised.  Switch back to "Local" and it continues to work OK.  Head scratcher.
On world move ( Only Z  up down )
On local move ( X Y Z  No problem ) .
