SWF loops infinitely
https://forum.reallusion.com/Topic285994.aspx
Print Topic | Close Window
By joepixxy - 10 Years Ago
I have searched in this forum and online but couldn't find any solution.
I have created an animation in flash and I wish to import it into CTA2 and convert it to animated prop
You can view the animation here
http://animation.pixxycreativities.com/wp-content/uploads/sites/18/2016/03/animated-wine-glass-gif.gif
The problem I am having is when I import it into CTA2 the swf loops infinitely, and doesn't stop.
Please is there anything I am missing?
Thanks.
By vidi - 10 Years Ago
Extract  a Single Image of you animation
Use the Sprite Editor for  switch to this  Image.
Thanks for the quick reply.
Please is there any tutorial on this? manual or video?
Oh, I think I have found what you are talking about;
is it this?
http://manual.reallusion.com/CrazyTalk_Animator_2/ENU/Pipeline/08_Animation/Sprite_Switch_Animations.htm
By jlittle - 10 Years Ago
Typically for an animated prop you will have two (2) static images (Start & End) an one (1) animated image (Loop).
You use the static Start image to show the prop before the loop starts.
Then you switch to the animated Loop image at the frame needed.
When the loop has completed you then switch the sprite to the static End image.
See my tut on how to use animated props HERE and you will see what I mean.
Jeff
Thank you all for your help. I've got it now.
jlittle, your tutorial was very helpful!
