How to set Photoshop path inside Iclone?
https://forum.reallusion.com/Topic284506.aspx
Print Topic | Close Window
By Pochontas - 10 Years Ago
I've re-installed Photoshop on a different location some time ago and now when I'm inside Iclone and on some prop material and click "Launch" button to open the image in Photoshop, so that I can edit it, I get the message "Failed to launch image editor". So is there some way to set different path of Photoshop exe file in Icolne?
By wires - 10 Years Ago
In iClone 5 click on the Preferences icon at the top left:
https://forum.reallusion.com/uploads/images/52b5d3a9-802b-46fd-b228-07d6.png
In the Preferences window click on the Folder icon beside the Texture Window and locate the EXE file for your paint program.
https://forum.reallusion.com/uploads/images/c9a4078e-21e0-4041-8d61-905e.png
In iClone 6 open the "Edit" menu and click on Preferences at the bottom (or use Ctrl+P) and locate the EXE file.
https://forum.reallusion.com/uploads/images/f796345b-f909-4552-b48c-8e84.png
OK super thanks!
By animagic - 10 Years Ago
To add: there have been reports in the past where the setting didn't "stick". If that happens, run iClone as Administrator and then set the editor. That should resolve that issue.
By Kingdom Geek - 10 Years Ago
Can you link and use photoshop elements or only photoshop?
By Snarp Farkle - 10 Years Ago
Kingdom Geek (5/19/2016)
I imagine it would open it, mine opens PaintDotNet just fine.
By justaviking - 10 Years Ago
Snarp Farkle (5/20/2016)
I link to GIMP, and it also works fine.
Strange things can happen, but I expect Elements would work also.
By iOguqGpA - 10 Years Ago
"run iClone as Administrator" thank you, animagic!! It goes well.
