By matthew_worrall - 9 Years Ago
Iclone 6 Hi I have tried to create an idle loop but there is always a noticeable delay when the loop restarts and the 1st keyframe isnt copied. Here is my process 1. Import idle clip boxing and record 100 frames 2. Break the clip at frame 3 (you cant break at frame 1 or 2 for some strange reason) 3. Copy the broken clip to frame 100 4. Loop the clip and it there is a weird pause as it loops 5. Even though I have copied the motion keyframe it doesn't match in frame 100
I followed the tutorial here...https://www.youtube.com/watch?v=yPUVmBqR0S8
Any advice would be greatly appreciated
Silly me. I had used the direct puppet and the delay was the delay between pressing space to record and the mouse moving
By pumeco - 9 Years Ago
Just a few tips here : - If you make a mistake on only part of a recording, you can save the good parts by slicing and chopping the bad part out using the timeline. - I hear there's a way to record at half speed using a key combination, though I haven't tried it yet and can't remember how it's done.
By animagic - 9 Years Ago
pumeco (5/1/2016) - I hear there's a way to record at half speed using a key combination, though I haven't tried it yet and can't remember how it's done. Pressing "Enter" instead of the space bar will record at half speed. It even says so in the interface should you ever forget...:unsure:
Cheers Job, but it does nothing for me and I can't see where it says about it either, where does it say that?
By Lamias - 9 Years Ago
I saw this and tried to press enter, but it doesn't do anything to me either.. Furthemore, it's the first time i hear it. Where does it say it?? :O
I've searched the documentation for "50%" , "half speed", and "half speed recording" - and still can't find anything about it.
Then again, I see Reallusion have fallen for allowing data-mining Google to handle their searches, so it's no surprise the search is as crap and irrelevant as Google and YouTube search is. Would be much better if they went back to their own search system, one that actually searched for what we're looking for instead of what Google (based upon it's data-mining across the web) wants to give us :exclamation:
I take it this feature no longer exists then :Whistling:
pumeco (5/3/2016)
I take it this feature no longer exists then :Whistling: Sorry...:blush: It still exists for the Face Puppet. It USED to exist for the Motion Puppet as well, but never for the Direct Puppet AFAIK.
Cheers Job, no wonder I couldn't find it, I was hoping it worked with Direct Puppet and Motion Puppet. Shame it's only for the face cause it would be ideal to have for Direct Puppet!
