PopVideo 3 unable to import file in MP4 format
https://forum.reallusion.com/Topic281364.aspx
Print Topic | Close Window
By Zeronimo - 9 Years Ago
I strictly followed the procedure described in the documentation :
https://forum.reallusion.com/uploads/images/0a4cd5fb-4490-4729-8982-e9e8.jpg
I tried with the "K-lite Basic" and "K-Lite Mega Pack" and the result is the same I get the message:
https://forum.reallusion.com/uploads/images/5ce09ca3-dff2-47de-a87d-c3b5.jpg
I have many many GreenScreens in MP4 format and I would avoid having to convert them to AVI before using them.
Is it possible to remedy this?
By Peter (RL) - 9 Years Ago
Unfortunately there is no one standard format for MP4. Generally installing the K-lite pack will allow you to use MP4 videos with popVideo but if the videos you have use a specific codec that even K-lite doesn't support, then sadly you may not be able to get them to run.
Try using a codec identifier like GSpot to check your videos. This should tell you which video and audio codecs are being used and identify any problems.
