Iclone4 Head Import
https://forum.reallusion.com/Topic28090.aspx
Print Topic | Close Window
By Saint - 17 Years Ago
I have followed the whitepaper on creating a headmorph, (using zbrush), to the letter. However, when i export the headmorph file it is exported as a vns file and not an iface file and thus iclone cannot pick it up in the custom file when clicking on import. I tried placing the file directly in the custom folder and it shows up once iclone is run but when i drag the file onto a G3 avatar, iclone  then CTD's. (crashes).
I though initially that i had maybe 'over-morphed' the head so i used the original template unchanged and duplicated the procedure which had the same effect.
Has anyone yet headmorphed into iclone 4?
By Adelio - 17 Years Ago
I'm experiencing the same problem with my iClone PRO 4.02!
By Peter (RL) - 17 Years Ago
New iClone4 developer tools are coming soon which will help resolve some of the issues being experienced. There will be an announcement on the forum as soon as they are ready.
By Corvega - 17 Years Ago
Has a patch been done to fix the Zbrush problem?
setroc2 (12/31/2009)
Hi SetRoc,
There will be a new G4 head template released in the Developer Center soon which should help with the problems you are having.
You can find a little more about these issues in the thread below.
https://forum.reallusion.com/Topic35443-13-1.aspx.
By Corvega - 16 Years Ago
Anything yet on this. Its been a while
By W.VEEKE - 16 Years Ago
i wonder: do you know that it is easy to morph the heads right away in Iclone see examples
Hi,
I wonder, did you know that you can easily morph the head in iclone itself.
