By post_76 - 9 Years Ago
I'm building my own character using swf sprites from coreldraw. It seems it puts the pivot points in the middle of the sprite and not by the joint. How do I move them?
Oh found out how... Apparently I need to be extremely precise on clicking the pivot point. Can I rotate the pivot point without rotating the sprite? In case I was a tiny bit off while designing
By Ibis Fernandez - 9 Years Ago
yes you can rotate the points anyway you like it only uses the position information, It doesnt actually matter what the size or rotation of the point is.
