By jamie3d - 10 Years Ago
I'm trying to get a child model from Daz 4.9 to3dxchange 6...
If I use the export rules suggested on the forum i.e Genesis2Male ignore, all the child morphs (zevo) get ignored and you end up with an adult?
if you don't include the ignore rule you get the child but the rigging borked up and the clothes don't fit properly.
I'm guessing I need a different export rule set up in Daz something that will ignore genesis 2 male but not ignore the zevo morphs.
is there an expert in the house that can help me out?
Cheers
J
By vidi - 10 Years Ago
In the DAZ Export Setting is selected > merge Clothing in the figure skeleton ?
By Lordhi - 10 Years Ago
I don't know if it is true for Zev0's morphs, but have you tried to lock the morphs in the parameter tab?
By Snarp Farkle - 10 Years Ago
This is an example of the settings I use for all my .fbx exports and rarely have an issue. If there's anything in the "FBX Morph Export Rules" other than "Final-Anything-Bake" select it and delete it and click on "Accept". One other thing that might be a problem is that certain clothing items will interfere if they are parented to body parts of the character, after they have been fit to the character it's ok to un-parent them or change the parent to the "RootNode", or just change the problem clothing items to an object if they still give you grief. As far as morphs go I've not had a problem with them in 3Dx other than the chest bone sometimes needs changed to keep the chest from getting all distorted. Try these settings and see if you still get the issue.
Thank you everyone, I tried all of your suggestion.
Thank you Snarp farkle! Your settings did the trick.
By Skuzzlebutt - 10 Years Ago
don't forget the transfer utility most times you can get any generations clothes etc to work on export.
