How do you put extra content into Iclone 5?
https://forum.reallusion.com/Topic272370.aspx
Print Topic | Close Window
By SofiaBlues - 10 Years Ago
I recently got a few downloads like some clothing and some hair and props.
How do I import them into Iclone 5?
By animagic - 10 Years Ago
SofiaBlues (2/14/2016)
It depends. If they are installer files (.EXE extension) then you need to double-click them and they will be installed. We are now at iClone 6 so you have to make sure that the content is compatible with iClone 5.
Some content, including anything from the MarketPlace, is distributed as an .RLD file. Rather than saving that file you need to select 'Run" when prompted. It will then download the content and install it.
By GrannyJ - 10 Years Ago
It is very easy to install Marketplace content into iC5 (provided the items are compatible with iC5). When you launch the installer from the marketplace a popup window opens:
https://forum.reallusion.com/uploads/images/2b39865d-83c6-449d-8139-173b.jpg
Simply click on the blue writing to install to a specified version. Once you click on the link, another pop-up window will open:
https://forum.reallusion.com/uploads/images/a60bb55e-6bd4-44bb-a921-9db5.jpg
Simply place checks in the boxes for installation to the SW version desired & click the OK button & as long as the content is compatible with that version, it will install there.  Easy peasy! :)
