Can't Open CT8 after Installation
https://forum.reallusion.com/Topic270502.aspx
Print Topic | Close Window
By circleme2011 - 9 Years Ago
I downloaded the CrazyTalk8_Pipeline Enu, CrazyTalk8_Resource Enu, CrazyTalkBonus_Pack Enu.
I installed the CrazyTalk 8 Pipeline Enu with my Serial Number. The software should start immediately after the installation, but then I got this error message:
_______________
CrazyTalk 8 AP has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
_______________
After this message, the software shut off. Whenever I double click the CrazyTalk 8 icon on the desktop, I keep getting the same error message. I use Windows 10 OS, DirectX 11.2 version.
Can anybody help me solving this problem? I hate to return it because I really like the idea of CT 8.
By Kelleytoons - 9 Years Ago
Make sure you've updated the drivers for your graphics card.
Also, go into your account and you'll see a place where you have the "patch" for CT8.  Go there and you'll find the latest version of CT8 (it'd odd, but it isn't a patch).  Uninstall the one you have and install this new one and see if that makes any difference.
Dear Kelleytoons,
Thank you for your answer. I did what you advised me to do and downloaded the latest CT 8 and the patch as well, uninstall the older CT8, reinstalled the newest CT8 and the patch as well, but still get the same error message. I was able to install CT 8 but can't open it.
My computer is a brand new computer, Dell Precision 5810, powerful for all 3D works (animation, rendering, modeling). I installed latest Maya, ZBrush, 3D Max without any problem. This is the first time I ever encounter 3D software crashing problem after successful installation.
By Zeronimo - 9 Years Ago
hi Circleme2011,
see this post : https://forum.reallusion.com/FindPost268798.aspx
No, what I'm saying is to NOT install the old version -- the "Patch" isn't a patch but a complete version.
So try this again -- uninstall what you have, reboot, and install ONLY the "patch" and see what happens.  After that, put in a trouble ticket (assuming you haven't already).
By Peter (RL) - 9 Years Ago
circleme2011 (2/1/2016)
_______________
_______________
Hi..
Please check the thread zeronimo posted for reference, but if you still have problems, then please contact our Technical Support department using the link below. They will be able to help advise you further with this issue.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
Thanks.
Hi friends,
Thank you so much for your information. The customer support already solved this problem. Apparently, there is a bug in the Dell's Backup and Recovery software. I download and install the upgrade from Dell and that solved the problem. I can open the Crazy Talk 8 now. Horraaayyyy.... thanks again for all.
