How to create a slideshow
https://forum.reallusion.com/Topic268839.aspx
Print Topic | Close Window
By hv@p24 - 10 Years Ago
Hi,
I'm trying to show different Images on a surface. I used a billboard and changed the image after scrolling the timeline but the Image changed for all frames. So my question is: How can I build a slideshow on the Scene / on an objects surface?
Many thanks for help in advance.
Best wishes ... Horst
By animagic - 10 Years Ago
hv@p24 (1/18/2016)
Hi,
The only way I know to show different images is to have a different plane or billboard for each and then use the Visibility switch to make only the one you want to show visible. Another option is to create a video of the still images with the desired timing for each and then place the video on the billboard. That may be more practical if you have many images.
Thanks for your help. I'll try this.
By wendyluvscatz - 10 Years Ago
Another reason I wish iClone did image series import, I use video and fortunately wmv is supported so throwing something together in WindowsLive moviemaker not hard but certainly an extra step.
