Bring Back RGB+A Export
https://forum.reallusion.com/Topic268420.aspx
Print Topic | Close Window
By JC Weatherby - 10 Years Ago
We could export images with transparent backgrounds in iC5.  Not so in iC6.  This is a valuable feature that will allow us to do more outside of iClone if we need to, such as composite an iClone element in Adobe Photoshop, After Effects, or Premiere.  RGB+A for both images and video.
Recently I used iClone to create a motion graphic as an overlay for video.  Without the Alpha export, it meant I had to do a luma/chroma key adjustment to make the background go away.
By Cricky - 10 Years Ago
Actually PNG is assumed as the default to export the Alpha Channel. It seems to be the only format however.
JC Weatherby (1/15/2016)
RGBA in Photoshop is 24bit PNG, or 32Bit TGA.    In After Effects RGBA can be prescribed for AVI and - I think MOV - as well as PNG / TGA image sequences.
By animagic - 10 Years Ago
Rendering with a black 2D background gives you a 32-bit PNG with a transparent background.
animagic (1/26/2016)
Thanks for the heads up!
