AXIS NEURON PRO doesn't broadcast
https://forum.reallusion.com/Topic267948.aspx
Print Topic | Close Window
By mtakerkart - 10 Years Ago
Just to mention that the pro version of Axis Neuron doesn't works in a broadcast mode. I uninstalled it and re-install the public version and it works.
If you can fix this , it will be very cool :-)
By tycho6 - 10 Years Ago
Hello mtakerkart !
Thanks for the info... !
Since the AXIS Neuron PRO version is still not available (in the store) I am curious how you got it   ;-)
Is there a Perception Neuron AXIS Pro Beta program ?!?
And if so - how to get into it  :-)
I contacted Noitom, but did not get an answer yet . . .
I also would like to test the features of the Pro version and find out if it is worth the extra money before buying it actually.
The additional features read interesting - can you tell about your experience (aside from broadcast mode issues) ?
Especially concerning calibration and motion data smoothing   ;-)
Regards,
Marcus
@info
I didn't use the pro version because it doesn't work with Iclone , I remove it . I'm in production now. I receive a personal link from Noitom because I own a 18 neuron kit.
But in a few days I will use the pro version.
By jamie3d - 10 Years Ago
I'm having the same problem, everything was working with axis standard bt got sent the link to the pro version and it no longer broadcasts?
it will connect but preview and record stay grayed out.
Although hitting it with a rock would be cathartic, it turns out the answer, for those having trouble was to select the "use old headers" checkbox in the axis settings menu.
Cheers
J
Soooooooo many Thanks Jamie!!!!! It works!!!
Yesterday Noitom had release the official Axis Neuron Pro app for all  Neuron owners as permanent liscence for....FREE!!!!! :w00t:
Thank you every all body many etc.....
By Sifr - 10 Years Ago
mtakerkart (2/13/2016)
Where is the link?:w00t::w00t::w00t:
By Ibis Fernandez - 10 Years Ago
I've had better results so far just capturing to Axis and using 3dXcange to convert the data to motion.
