Program crashes after I add face anchor points
https://forum.reallusion.com/Topic267008.aspx
Print Topic | Close Window
By PrinceCharming - 10 Years Ago
Every time I create a new actor and when I add face anchor points and click next..the program freezes and crashes..I must close the program and re start..but I can only make it to that one point....what's the deal...I believe my computer mets minimum requirements
By Peter (RL) - 10 Years Ago
What are your computer specs (including graphics card) and are you referring to face fitting using CrazyTalk 8 Pipeline?
Thanks.
Duo core E8400 @300 GHz, windows 7 sp1, 8 GB of ram (7.84 useable), 64 bit OS, these are my computer specs, still after I do the face anchor points in  create new actor then click "next" ...the programs says "Program stop working" over and and in the same spot
By animagic - 10 Years Ago
PrinceCharming (1/6/2016)
You didn't mention your graphics card. It should be a newer NVidia or AMD card as specified here: http://www.reallusion.com/iclone/iclone_requirements.aspx. You also need to be able to run under DX11.
I don't think it's a hardware issue  because the program works for 5 min, importing actor,cropping, adding anchor points etc,,it's after I put in the anchor point I get the pop up saying the program/windows 7 has stopped working, and the program closes, after I did some google searches , everything points to a setting issue , and I tried running the program in other capability modes, the same thing happens. HELP
