By RobertoColombo - 11 Years Ago
Hello RL community,
I am creating this thread to collect some feedback from those who owns and used the Kinect with iClone 6. The main points being:
1. system set-up: plug&play or plug&pray ? 2. usability: what can be animated and what can not? 3. outcome: how much adjustment is usually needed for the animations captured from the Kinect?
Thanks in advance for your kind help Cheers
Roberto
By Kelleytoons - 11 Years Ago
I love using my Kinects (I have two) with iClone but I suspect your post should really read "RL Kinect Software" because using a Kinect or two with iClone and using the RL Kinect software are two very different things.
The RL Kinect software is *okay* -- not great and not something I'll ever use again, but has some uses. I would highly recommend checking out the ipisoft and Brekal as alternatives to it (and I give a run down on how all three compare in another thread).
Hi Kellytoons,
thanks for the answer. From it, I understand that I know little about Kinect and Reallusion Plug-in :) So, when you say that you love Kinect but when combined with RL plug-in it is "okay", I read into this (pls, confirm if am I wrong) that the camera works well, for other applications (XBox ? or which one?) but the process to convert a movement, grabbed by the camera, into an iClone iMotion is still not so smooth. Is the above correct ? Is it possible (and better ?) to grab the movement with the camera, use other SW to create , for example a FBX or BVH, and then convert it into iClone format with 3DXchange ?
Thanks Cheers
Roberto
Right, what I'm saying is that the Kinect works fine to capture movement that you can use inside of iClone BUT you need to use the right software.
I did summarize this in another thread, but a very quick recap (again, all IMHO) is:
1) RL's Kinect plug-in does a horrible job at keeping the feet stable, a fair job at capturing arm movements. It's real strength is it allows you to capture upper body only (so you can sit in a chair and do your mocap if that's all you need). It works in real-time but the amount of cleanup you have to do afterwards makes it almost unusuable. I'd rate it a C-.
2) Brekel's Kinect plug-in is much better at capturing arm movements. It's fair at capturing feet (still has sliding feet but not as much). It also works in real-time but I could never get the feet stable enough to use it well. I'd rate it a C+.
3) iPisoft's Kinect plug-in is superb at capturing both arm and leg movements but it does not work in real time. There is zero time needed for post processing, however, so it's about a wash in terms of effort. I'd rate it a solid A as long as you understand it's a subscription model (which means you have to pay a yearly fee to use it). For a few years the cost will roughly be the same as either of the above two plug-ins but after that it will be more expensive (however, after that I do believe mocap will have a sea change and none of us will need anything like this).
I ended up buying not only the base iPisoft plug-in but the one that uses two cameras, so I can do complete turnarounds (none of the plug-ins mentioned above will handle that). I literally have no restrictions, other than single actor only (and no finger capture) on what I can mocap, and it's very impressive. The good news is that there are demos of the two alternatives (I don't know whether you can demo the RL plug-in or not -- I bought it without seeing). I would STRONGLY recommend you try at least the two (and perhaps RL's if there is a demo) before you buy any one of them.
Hello Kelley,
thanks for the detailed answers: very useful and I truly appreciate the time you spent to answer me. I will pass your info to the person who asked me to make some research about the Kinect (I am just helping him with the English language).
Cheers
Roberto
