How can I make a high poly character with CC?
https://forum.reallusion.com/Topic265375.aspx
Print Topic | Close Window
By KSAM - 10 Years Ago
Hi, I mentioned character creator are low poly somehow but I need 80"000 poly for my character! is there anyway I will make a high poly character with cc?
UP
By wires - 10 Years Ago
In a word, No!
Just why do you need such a high poly count?
By planetstardragon - 10 Years Ago
hrmm...a high poly count for a new animator would give the illusion that it would render better  ( not necessarily true )...
for a more experienced animator,  for the ability to mod more detail into the mesh. without having to re-rig... (ie - someone that likes to model and animate, but hates rigging .) -  to up the polycount,  you would have to export a 'base' model ( unless you purchase an export license for an expansion model )
Then go to an industrial grade software,  like autodesk maya, max ..or something like modo, or possibly blender ....import the mesh with the rig ,  and subdivide. Otherwise,  nope.   Not unless you export the mesh and re-rig it ....the mesh is linked to the bones and weightmapping -  the only way to increase the poly is in a software that can adjust the weightmapping along with it,  and the cc / iclone software does not have such subdivision tools
By wendyluvscatz - 10 Years Ago
There is one very good reason for very high poly
3D printing
I up the values a lot for my XYZ printer but thats on the posed exported holes closed in meshlab stl file
