By Eric (RL) - 11 Years Ago
Got a cool celebrity 3D heads or an awesome animation clip you wish to show? You come to the right place!
Post all your finest works here and maybe you'll get featured on other Reallusion channels or get an email from us!
By duchess110 - 11 Years Ago
Well it is not a Celebrity nor an animation just a picture of my first attempt and making a head from just a front image.
By vidi - 11 Years Ago
very beautiful !:) duchess my version is still download .:crazy: I'm so excited
By Tomasz F - 11 Years Ago
Hi Duchess, She is very nice, well done ;-) I am still downloading my version - could be nice to see the original picture as well as the CT8 output ;) Tomasz
Thanks for the comments Tomasz F and vidi. I do like trying out new things and tend to dive in and read manuals etc after. Anyway in the Showcase Yourself I did a Make Someone Happy Video using one of My Yam Yam Characters and because I had saved the MotionPlus file I thought I would make a new face in CT8 and take into Character Creator then on into iC6. So here is Bruno doing Make someone Happy.
Hi Duchess, He looks great! My first attempt in CT8 was not so good, but nice to see what can be done and keep improving the skills ;-) Tomasz
By bobdoyle - 11 Years Ago
Well, here's what I played with today...
This started as a quick test for lip-syncing and I decided just to keep going with it, even though it's less than 30 seconds.
I did spend some time - not as much as I could have - with adjusting the visemes for the voice so the talking looked more accurate based on what I was saying.
The model is based off an older picture of me, and the things I say don't really make sense. I brought the final render from CT 8 into Sony Vegas for sound and some "post."
Nothing elaborate.
And as far as "celebrity heads", here's the same file with Nicolas Cage's head. :)
By bluemidget666 - 11 Years Ago
UK MP Duncan (spit) Smith :)
 Not perfect but not too bad for a first attempt. I hope RL stock Backstage with some more clothing and footware finding them a bit limited at the moment (HINT HINT ) :)
By animagic - 11 Years Ago
I did something with a photo of myself that was far from ideal. Still it got a resemblance, but somewhat younger. Lighting is indeed tricky to make things look the same in iClone as in CT8.
We''ll keep trying...
Putting 2 in this post. Bruno has now become stage struck :D and wanted to do another. ha ha. So here is Bruno singing the Ugly Bug Ball,
Next is Adel Singing Rolling in the deep. In the video it shows the picture I used to create the face in Ct8.
Now I must get back to my Yam Yam males they are getting restless waiting for final testing before joining the Marketplace.
Hi All, I like your Characters. It's looks for me far better than with the old face fitting tool.:)
Here is my first attempt .
By theschemer - 11 Years Ago
duchess110 (12/20/2015) Putting 2 in this post. Bruno has now become stage struck :D and wanted to do another. ha ha. So here is Bruno singing the Ugly Bug Ball,
Hi Duchess, Great job with only using a front facing image with Adel. How did you get the face and neck to blend so well? My first attempts left the neck looking a gray color and I could not figure out how to get it to match the face. Thanks, TS
By patrick.gerard - 11 Years Ago
I don't know if this helps but I find setting the head texture to self-illumination captures some of the look. Not quite enough for my tastes but the resemblance starts to improve and details in the texture become apparent. I suspect the bump map may be partly to blame and I also suspect CT8 employs self-illuminated textures.
animagic (12/20/2015)
I did something with a photo of myself that was far from ideal. Still it got a resemblance, but somewhat younger. Lighting is indeed tricky to make things look the same in iClone as in CT8.  We''ll keep trying...
Hi theschemer This does not always work but there are 2 things that I have tried 1 - Within CT8 when doing the blend for the rest of the head to match I will select a blend colour quite low down the face towards the neck. 2 - In iClone try playing around with the diffuse colour on the head and body. They are usually white so I have tried various shades of grey on one or the other to try and get them to blend better. Hope this might help as I say it does not always fix it.
By JIX - 11 Years Ago
Ermm ... the only convincing CT8 heads so far, are the samples coming from duchess. Don´t take it personal folks, but the others all look a little mask-like. Blame it on the 3D Head Creator. ;)
duchess110 (12/20/2015) Hi theschemer This does not always work but there are 2 things that I have tried 1 - Within CT8 when doing the blend for the rest of the head to match I will select a blend colour quite low down the face towards the neck. 2 - In iClone try playing around with the diffuse colour on the head and body. They are usually white so I have tried various shades of grey on one or the other to try and get them to blend better. Hope this might help as I say it does not always fix it.
Thanks Duchess, Every tip and trick helps. I have been waiting for a long time for the CT8 option to create characters and now that it is here, I need to get the most out of it. I tried the skin changes in IC6 but they didn't work at all. Back to try these new tips. TS
JJJAM (12/20/2015) Ermm ... the only convincing CT8 heads so far, are the samples coming from duchess. Don´t take it personal folks, but the others all look a little mask-like. Blame it on the 3D Head Creator. ;)
Well, we're learning, and I found for example that the initial photograph is very important, such as resolution, evenly lighting, etc. It also looks different in iClone compared to CT, but Eric posted some tips to remedy that. Things will get better and I thingk with practice good results can be obtained. I do like the face-fitting tools; they have vastly improved.
the others all look a little mask-like. Blame it on the 3D Head Creator. Maybe you mean draw-like , if so, in my case it fits exactly .:cool: Not all see in the CT8 only a photo head creator , for me it bring my drawing Images to life. Also Blue's Character is toonish, expected you really a pseudo real head there? :pinch: Actually I would only use CT8 , but I can there not use my accessories.:crying: I hope RL will fix it.
By planetstardragon - 11 Years Ago
@animagic @vidi
I was refering to the capabilities of the 3D Head Creator, not to the skills of you guys. Just trying to figure out, if I need this tool, or not. So thanks for posting those samples!
I would say skip side fitting and do it manually for the time being. It always comes out deformed when I try it and my suspicion is that slight angle variation or photos of different scales mess it up. If I'm doing a celebrity face the way one typically does a CT face, I'm not going to match the scale and vertical alignment of the two photos typically and you can do much more refined work within Character Creator if you have the patience and plan to take it further.
I figured I'll show you the full process. Here is a base image of Donald Trump.
Here is my Donald Trump in Crazytalk (no necktie because the installer for people who bought Party Fun early still doesn't install to CT8, hair is backwards because I have no means of inverting it at this point):
I then import into Character Creator. All options are set for high quality textures. Make sure your CC character is selected. Also make sure you have both chosen the default morph and clicked "reset" on the head as the true default is only achieved at this point and CC will otherwise go for a hybrid of the two morphs.
To reacquire the hair in CC, I had to manually import the matching hairstyle from iClone as a head accessory because it isn't recognized as a hairstyle. (I think it's the "suave/charming" hair). I have to replace the eyes because of a bug.
Dress Up Showtime doesn't install anything to iClone or CC so while I DO have Party Fun neckties there, I have no shirts they clip onto.
So we'll compromise and go with an open shirt (like Mason's) before we go into iClone:
Now, you can recover some of the original look by giving Donald's skin self-illumination.
I set self-illumination on skin for body and head each to 75:
And for fun, here's Trump in Indigo, one minute render, around 35 samples per pixel:
There is some likeness degradation at each step although I think Indigo manages to restore some realism to it. Now, something to keep in mind about CT8 is that it inherits some of its base features including head size from the previous actor. So if you start with Sammy the Ogre, you get a bigger starting head and some room for a more Pixar-like effect.
I went through all of these steps starting with Sammy in place when I created a Trump avatar with the same photo and wound up with this (different hairstyle) as my "Pixar Trump" style take in iClone/Indigo.
So I'd be more inclined as an iClone user to think of CT8 as a sketching tool (and a decent one for cartoon/caricature) than as a likeness solution. Plan on iterating whatever you do in each step and be prepared for an outcome that deviates and I think you have an interesting character generation tool at least.
Also, as a piece of advice, I think the average CT user would benefit if Reallusion offered:
1. Rotation, resizing, and alignment of source images within Crazytalk.
2. Less emphasis on side fitting. It can mess things up more often than it fixes them which will lower people's impression of the product as they try to do something with only marginally better returns.
3. An option to automatically make all non eye and nose features symmetrical. Eye and nose assymetry are important as no source photograph is perfect but chin and ear assymetry really belong more as an advanced feature (and I'd rather do those in Character Creator).
4. Shifted expectations towards cartooning/caricature.
5. I think it's a mistake to release content that can't be used across the products going forward. The tricks I had to use to get suave and charming hair in character creator were non-intuitive. The idea that I have a necktie in three programs (once they get me the installer for CT) but only have a shirt that can use it in Crazytalk is non-intuitive. It also destroys the possibility of any workflow that doesn't end with iClone as I had REALLY hoped to be able to create characters who could be used in CT and iClone so that I can:
- Create a character in CT. - Port it to iClone for body animation and action. - Go BACK to CT for faster rendering of talking heads sequences in a movie, using a pre-rendered background from iClone.
Can't do that. Well, I can but it means the stuff I do in CT in that last step will be with a 2D avatar.
That's my feedback. Some nice things. Some issues with bugs. Some differences of opinion on design.
Oh and my first test of CT to iClone was the late Christopher Reeve, which I might as well share here:
[YouTube]http://www.youtube.com/watch?v=ZKoa9xxgRsw[/YouTube]
patrick.gerard (12/21/2015)
I would say skip side fitting and do it manually for the time being. It always comes out deformed when I try it and my suspicion is that slight angle variation or photos of different scales mess it up. If I'm doing a celebrity face the way one typically does a CT face, I'm not going to match the scale and vertical alignment of the two photos typically and you can do much more refined work within Character Creator if you have the patience and plan to take it further. I figured I'll show you the full process. Here is a base image of Donald Trump.  Here is my Donald Trump in Crazytalk (no necktie because the installer for people who bought Party Fun early still doesn't install to CT8, hair is backwards because I have no means of inverting it at this point):  I then import into Character Creator. All options are set for high quality textures. Make sure your CC character is selected. Also make sure you have both chosen the default morph and clicked "reset" on the head as the true default is only achieved at this point and CC will otherwise go for a hybrid of the two morphs. To reacquire the hair in CC, I had to manually import the matching hairstyle from iClone as a head accessory because it isn't recognized as a hairstyle. (I think it's the "suave/charming" hair). I have to replace the eyes because of a bug. Dress Up Showtime doesn't install anything to iClone or CC so while I DO have Party Fun neckties there, I have no shirts they clip onto.  So we'll compromise and go with an open shirt (like Mason's) before we go into iClone:  Now, you can recover some of the original look by giving Donald's skin self-illumination. I set self-illumination on skin for body and head each to 75:  And for fun, here's Trump in Indigo, one minute render, around 35 samples per pixel:  There is some likeness degradation at each step although I think Indigo manages to restore some realism to it. Now, something to keep in mind about CT8 is that it inherits some of its base features including head size from the previous actor. So if you start with Sammy the Ogre, you get a bigger starting head and some room for a more Pixar-like effect. I went through all of these steps starting with Sammy in place when I created a Trump avatar with the same photo and wound up with this (different hairstyle) as my "Pixar Trump" style take in iClone/Indigo.  So I'd be more inclined as an iClone user to think of CT8 as a sketching tool (and a decent one for cartoon/caricature) than as a likeness solution. Plan on iterating whatever you do in each step and be prepared for an outcome that deviates and I think you have an interesting character generation tool at least.
Patrick, Good info. Thanks for taking the time to post it. Every bit helps. ;) TS
patrick.gerard (12/21/2015) Also, as a piece of advice, I think the average CT user would benefit if Reallusion offered:
Add CROPPING to #1 like CT used to have too. TS
More playing, going from CrazyTalk to CC to Iclone and back :)
By wendyluvscatz - 11 Years Ago
I compared 2D and 3D in CT8pipeline and the exported result on a CC iAvatar in iC6
I will admit the result is better than face fitting on previous iAvatar generations but wish I could override parts like ears and tops of heads that IMO look awful and just do the face to hairline and before neck side on but sadly its a a full head morph
By pmaina - 11 Years Ago
iClone5, without CC or CT8.
when I saw the avatar of trump, it made me laugh a little because he looked like hilary - and it made me think of that conspiracy theory that all people in government are actually related ... so I looked it up ....
turns out - "Donald Trump and Hillary Clinton revealed to be distant cousins" http://www.dailymail.co.uk/news/article-3210778/Donald-Trump-Hillary-Clinton-revealed-distant-cousins-family-trees-share-set-royal-ancestors.html
looks like crazytalk can be used as an illuminati decoder ring! :ermm:
By brothertcoleman - 11 Years Ago
 Celebrity mug shots is a good source for side views.
Sorry for double post.
planetstardragon (12/22/2015)
This one looks better than the original! Very interesting....
This one was the hardest yet. I decided to use George Clooney as I had recently seen him on the TV. So found a picture on a Google Search the one you can see in the video and on YouTube found him reciting a poem by Dylan Thomas, but boy oh boy was it difficult in CT8 the reasons being he has quite small eyes and thin lips. So messed around with the picture in Photoshop made the eyes bigger and lips fuller. Then in Ct8 used that. I could not get any of the hairstyles to replicate his so this is the closest. It is surprising what a difference the hair makes so not really the result I wanted.. So after all I had done I thought what the heck post the video anyway here is the outcome.
EDIT Animagic I went and had a look what I had got in ic3 ic4 & ic5 as you suggested in below post and still not right so decided take him into CC again and put a crew cut on him also had a go at tweaking the eyes and mouth. Now replaced the video. Thanks for reminding me about a lot of stuff that I had not converted from VNS as I did not want to clutter up iC6
For iClone users looking for closed shirts with jackets and ties: Alley has a very nice Christmas freebie in her store.
I'm not so sure I would want the emphasis of CT8 head creation to be on cartoon look only; I like it to be more universal than that, catering to different styles.
@duchess: there is a IC3/4 hairstyle of a Navy officer or something that would do nicely I think: http://city.reallusion.com/ContentPreview.aspx?i=IC250D218ENU0108A002.
It should be mirrored, I notice.
so...it's no secret, im a fan of the supernatural tv show series!
Started this one Christmas Eve when I was finally able to get some me time, this morning after doing the housework and filling the recycle bin with empty cans and bottles and got hubby packed off to the Boxing Day Local Football Match sat and finished this.
By kimpen - 11 Years Ago
WOW, am having quite a bit fun and new challenges with CrazyTalk 8! Have a little problem with eye fitting! but think its ok for my first attempt. Don't have Photoshop, all artwork for faces are done in Xara, even the 'remodelling' of the eyes for this first attempt Happy New Year to all staff and members of Reallusion https://youtu.be/NycCvQPyQE0
By fpacheco1960 - 11 Years Ago
It is a bit tricky to get the photo to 3D Head in Crazy Talk 8 to achieve you desired model, but like everything else, you better better the more time you do it. One of my favorite book series is the Belgariad written by David Eddings. I am slowly creating the various characters form the series, and am using celebrities photos as a base for the 3d model. One of the characters is named Silk, a thief known by his rat -like large node. I did a search in google "famous actor with large nose" and the Adrian Brody(known for playing Houdini in the mini-series Hoduini), was the first name that Google search returned.
Here is the 3D model profile and portrait pictures along with the photo of Adrian Brody I used to create the head.
Sure am having fun with Crazy Talk, and IClone 6.
By O'Brixtor - 11 Years Ago
Seriously? Everything i've seen i this thread looks like shit !! It look's like something from a decade ago like GTA Vice City characters or something older...
For once, take a look at the eyes please. They are way off - all of them...
This whole CT8 3D thing is simply miserable. It's ridiculously bad... Can't see anywhere that we are facing 2016 here, guys. WTF!
In my opinion CT7 does a far better job than CT8. CT7 keeps the graphics right and clean like the org. picture, and it dosn't fuck up the eyes. Contrary CT7 is very very good at making the eyes, and the setting opportunities are much greater. Seems like i'm just on another planet again than all the rest of you regarding this CT8. The truth is that im so very disappointed with CT8, that i simply can not understand your enthusiasm with it? And i can not understand that Reallusion can't do better than this? (2016?)
and If I respond to that ...IM the bad guy lol...
so now i have to say,
"thank you O'Brixtor for sharing your insight, your views are appreciated, It makes me a better artist" ..... Which is TOTAL bullkitten...but I have to play along so everyone doesn't get upset at me !! not that anyone getting upset me has any impact, but in this case it does because i care about their peelings ....bah...
yeah, u know me, i'm going to rub it in!!
with that said,
Have a wonderful Holiday Ms/r O'Brixtor, i hope everything gets sorted out for you and you get the help you need and paid for.
i love everyone here very very much, so i won't be able to speak in defense of them because it upsets them, ( i'm really a monster when i'm on the defense, i admit .) but now I actually have to be supportive and kind of your comments for their well being. - the irony eh ?
-warm hug- :kiss:
By Kelleytoons - 11 Years Ago
Stardragon,
Your posted head was one of the nicest, but nearly all the heads here were pretty fantastic.
Don't worry, there are plenty old men like myself around here willing to say bad things about people -- the other poster was full of... um, well, full of the stuff that Santa puts in bad boy's stockings (and I'm sure it was a boy, and a young boy at that. He's just mad that he didn't get what he wanted for Christmas, although if he's better perhaps NEXT year -- otherwise, Krampus for him!!!).
Ha OK O'Brixtor
If you can tell me WHO my character does not look like, especially the eyes ill say your right, on the other hand if your talking out of your bottom and can not tell me who my character does not look like Ill call Bull on your post ok. :)
Kelleytoons (12/27/2015)
If you're refering to me (?), I think you should learn to "go for the ball, not the man". I'm 41 years old, and i know what im talking about. However I have read more of your posts in this forum, and in most cases i see, that we are far from consensus. Take a rest, dude!
It's all good, that you all love each other inhere, and have been here together for a long time. For all i care, you can go have sex all together... Meanwhile i'm only interested in the quality of the animations, and CT8 DOES NOT deliver!
you sound sincere and passionate about your views, those are wonderful traits! ♥
41? I have SHOES that are older than that. LOL.
Yup, we probably don't agree -- however, that doesn't mean you are right, just disagreeable <g>.
By NoKat - 11 Years Ago
A quick first try with an Anne Hathaway photo. It was low resolution and tilted. I rotated it a bit in PS but did no other prep (her teeth are showing in the photo but I didn't bother to fix it). I think it turned out pretty good for a first try with a low res photo. Hope animated gifs are okay to post.
@NoKat
yeah it looks ok for a first go, one thing that does kina annoy is the mouth issue. Like you said the teeth show but in CTA2 you can face fit and get the teeth removed so why didnt RL enable that in CT8. CT8 is not perfect but it along side CC is a much better alternative to the old Iclone 5 face fitting tools.
O'Brixtor (12/27/2015) Seriously? Everything i've seen i this thread looks like shit !! It look's like something from a decade ago like GTA Vice City characters or something older...
The 2D heads in CT8 are better than the 2D heads in CT7.
Most of what you're criticizing are 3D heads which are a new feature and we're sharing our problem filled attempts in an effort to provide feedback for feature improvements to what is a brand new feature.
patrick.gerard (12/28/2015) [quote]O'Brixtor (12/27/2015)
No, they are NOT! It's far from better!
Dear O'Brixtor,
"what if" they weren't trying to make it better, maybe they were just trying to make it different ? u know ...like chicken waffles ? example, with images, i haven't done anything with just images in ct8 that i couldn't do in ct6 ...i skipped 7..... but i also couldn't make heads in ct6 for iclone 6, and well mixing both 3d and 2D with a super ez format is ....different....new. 2D animators get to wet their whistle with 3D content and the 3D guys get to wiggle their toes in 2D.
better is also a subjective term, whats better for tom may not be better for mary, especially if it involves mary having to stay home with the kids cooking and cleaning, while tom gets paid to host a bathing suit contest. It's best for both that the bills get paid for them to keep their happy home, and both tom and mary are in fact working to a common goal, but ultimately it is a better perception for one party, as tom may get embarrassed at such events and mary enjoys the comfort of the home.
In conclusion, i think it would be best if you pointed out a feature with a common world view where others can agree with you and help support your thoughts, you want results, and I want to help you get them!
I hope this helps.
trying out to use CTA with caricature faces only to note that it will resolve itself to making more realistic facial features. so here I had tweaked a little with the face fitting and altered the skin tones... I still have problems with eyes fitting, oh well, surely I will work it out in time.... Have fun al l
Okay, alien heads reminded me of this image I downloaded the first day I got CT. Never even tried to make a head because I thought it would be too tough (not human enough) but I do like the way it came out:
@kimpen That looks really cool. I want to try other textures other than realistic human too. I wish there were more body types than the standard male/female, or at least a way to texture the bodies.
@Kelleytoons Nice job getting the morph close to the original. I'm having trouble with that yet. Anything too far off basic features and things go wonky. :)
I've been playing more with head fitting and using the auto motion and the puppet feature. Three youtube videos: One with the included Carlo texture, one with the Anne Hathaway actor and auto motion, and one with a jaguar texture and more auto motion and puppeteering. Oh, and physics.
this one got a few smiles on twitter - i did have to do a bit of 3d sculpting on it though to fix the nose and cheek area. - the whole texture altering in photoediting software got really tedious though, can't photoshop a face till in iclone, and if you try to recall the character back to character creator, it strips the texture, very limiting.
NoKat (12/29/2015) @Kelleytoons Nice job getting the morph close to the original. I'm having trouble with that yet. Anything too far off basic features and things go wonky. :)
Yeah, CT8 is very "human centric", which is the thing that surprises me the most since they touted how you could do animals with it (I guess only animals that look like humans, like apes and monkeys :>).
I have some Anime stuff I was trying and even there, as human as they are, the large eyes are a real issue. So I like to fool myself into thinking this is only their first pass and they will add capabilities to it that allow for more extreme variations. Time will tell.
Okay, on the subject of alien heads, here's another attempt to get something less human:
By 3DPiXL - 11 Years Ago
Kelleytoons (12/29/2015)
NoKat (12/29/2015) @Kelleytoons Nice job getting the morph close to the original. I'm having trouble with that yet. Anything too far off basic features and things go wonky. :)Yeah, CT8 is very "human centric", which is the thing that surprises me the most since they touted how you could do animals with it (I guess only animals that look like humans, like apes and monkeys :>). I have some Anime stuff I was trying and even there, as human as they are, the large eyes are a real issue. So I like to fool myself into thinking this is only their first pass and they will add capabilities to it that allow for more extreme variations. Time will tell.
I'm confused where did they tout that you could do animals, every video I watched showed human faces. Seems overtime I visit the forums someone is showing their disappointment in reallusion software. Im starting to think the only people that post these days are those that are looking for that allusive magic button to achieve their goals. There is no pleasing you people. Seriously go and learn 3dMax or Maya if you require so much control over your final output.
Always like to clear up confusion:
Here's the page: http://www.reallusion.com/crazytalk/avatar.html
And you'll see the info under "Non-Humans are Welcome"
But I understand, you can't see all the stuff that comes out from RL in various places. Perhaps "Animals" was too strong a marketing term for them to use, maybe just "creatures that belong to the ape family" or some such (but I used to work with a marketing department and I well understand how they operate).
And while I DID complain about the way certain things in CT8 work, if you pay attention (please! It's always a Good Idea) you'll see that I'm one of the people here who really LIKES it (and posts examples of what I'm doing with it).
I realize you're a newbee here, but once you've spent a bit more time on the forum and actually contributed folks will pay a lot more attention to what you have to say.
By texasvideographer - 11 Years Ago
wow, I never said anything that vicious, yet they deleted MY posts.....oh well.
By urbanlamb - 11 Years Ago
texasvideographer (12/31/2015) wow, I never said anything that vicious, yet they deleted MY posts.....oh well.
Just cause someone says it doesnt mean its gonna stay put and its okay.
Love, Joy, Puppies, Kittens!! Yay ☃ - Have a Wonderful New Year Everybody!
This is for Kelleytoons. :Whistling: I didn't spend more than five minutes between finding a frontal chimp image and fitting it, so no snark please about how awful it is. It was just to see if it was somewhat possible to do a chimpanzee.
That one is pretty good. Especially if that is a first try and you only spent 5 minutes on it :)
Right, primates are going to be the only real "animals" we can do (or at least those that fit the general primate category). A shame, because I KNOW a lot of folks would like to do cats and dogs (the ears alone would be a show-stopper).
But, no, I didn't think it wouldn't be possible and it's a good job (the real problem with apes and monkeys is going to be the lack of hair that we can put on them, but for alien sort of creatures they will work fine).
I just had to try it because you had mentioned primates. I also would love to see a basic animal head, with ears and muzzle that can be adapted to wolf/dog/cat. Of course it won't look as good without the physics fur.
Since you're here, Kelleytoons, I have a question because I think you have iClone 6? Is it possible to download the UV map somewhere for the 6 figure? I can work with the saved UV images but the actual map would be easier to work with. It appears that they are using the full map in CT8.
It *seems* to me all the maps were provided for those of us who bought the CC Essential Learning resource (or did that come as a bonus? I dunno, this old man can't remember anymore). I assume that's what you're asking, if the maps can be found somewhere other than having to buy iClone.
Maybe Peter (if he's still here in this longish thread) can shed more light on this -- perhaps they are even free somewhere.
Before
after -
By urbanlamb - 10 Years Ago
is that a dead rooster on his head? LOL
:blush:
By NoKat - 10 Years Ago
urbanlamb (1/1/2016) is that a dead rooster on his head? LOL :blush:
First, you owe me a keyboard, and second, I quite like the character. He looks like he does the daily news wearing a rug that no one notices.
NoKat (1/1/2016)
I love goofy characters you should see what I come up with for crazytalk and the animator. I am waiting till they update crazytalk animator 2 and then i will get the new head thingy as well. Suffice it to say that for some reason crazytalk brings out the .. well crazy in me and always has. Iclone doesn't have the same effect on me, but when I first started using the crazytalk package and then the animator I was making all kinda wierd things LOL. I have plans, but alas my pocket book is only so large so I decided to put off the purchase of the head thing until they release animator 3 cause I am sure there will be some sort of deal :D
so for now I can only spectate and ask stupid questions
By planetstardragon - 10 Years Ago
actually, come to think of it, if I painted him all yellow, he'd probably make a great monster canary! kinda like Tweety-bird's little cousin! lol -makes director hands-
He looks like he could be an angry bird.
By Rampa - 10 Years Ago
Still playing with the demo, but getting much better eyes now that I figured out where their settings are.
Also figured out some important stuff, like the toolbar across the top. It has settings for adjusting the eyes, just like in iClone. Also, like iClone, it is better replace the photo eyes. They load way to small, so go ahead and enlarge them. You'll also need to set them back further in the head.
There is also the texture tool, where you can export the head or body texture. Do this!!!!! It saves saves it at 2048 square, and holds all the detail. Just load it back on your head in iClone.
The eyes look pretty good. May I ask what image you are using?
it looks like I have irrefutable proof that apes evolved from pre-prehistoric canaries
PSD, that is awesome. Angry Birds have another weapon against those stupid pigs.
he seems to be turning heads on twitter! :w00t:
might be fun to give this guy a personality, "Tweet Tweet" in Barry White Voice with a brooklyn accent! -does director hands-
Is that Leonardo?
By royfriend2011 - 10 Years Ago
removed
By kimpen - 10 Years Ago
hahahhah....love it, your canary humanoid!
here's another video of 2 drawn faces...was trying out with skin tones and possibly markings on faces...this is how they looked. Eyes fitting much better - that is, closing of the eyes, have noted that face fitting in CTA 8 is based on the proportional aspect of a human face, A human face 'specification' is based on the eye, maybe this will help others who are trying out with photos - if the face is slightly out of forward facing, either tilted down too much or sideways, it might be an issue with face fitting... I find it easier to draw faces and apply it and it works...having a lot of fun...
:w00t:
I've been playing with eyes. Here is Mike with a bruised and bloodshot eye.
More playing with eyes and eyelashes. This might look good on an anime type figure.
By duchess110 - 10 Years Ago
Thought I would try and do a sort of Non Human Character (Chucky) well you can hardly call him a human can you. :D
so i found this profile of an interesting character ...
By Kelleytoons - 10 Years Ago
I LOVE how you turned a profile into a front facing image as well (made the eyes droop down a bit but otherwise very acceptable). Duh -- why didn't that occur to me?
Might not work well (or at all) on anything other than an extreme character, but it sure works well here.
I have to agree with Kelleytoons, that was really clever. So fun seeing what creative people are doing with the software.
thanks Guys :) - this technique works with all facial angles, I actually learned it from fixing normal face shots with bad shadows. As long as you have half of any face, you have a face. The rest is just a matter of perspective, literally.
REMOVED
So yesterday I was fooling around and got this so far (needs work because I'm going to put a normalized beard on him that actually projects):
This was done using a front and profile image, and I had to do almost zero refitting on the profile side. I'm still scratching my head over why this worked so well, as the profile was taken at a different time and under different lighting and the actor didn't even have a beard then. For some reason the profile was a perfect example of what to use to get it right, but I'm trying to figure out why it was so good when others I have tried required a lot more work to be acceptable (I'm not kidding -- the head came out almost exactly right with so little fitting it was a miracle).
Nice Character Face Kellytoons generated using both front and side images.
By O'Brixtor - 10 Years Ago
planetstardragon (12/28/2015) Dear O'Brixtor,
better is also a subjective term, ....
Said no Steve Jobs ever !
"Innovation distinguishes between a leader and a follower." - Steve Jobs
Here's a front view only "mummy" type head (it's a pretty lo-res image and I spent about five minutes on it in CT8 but I'm happy with the way it came out):
By animagic - 10 Years Ago
I wanted to do something with a Buddha picture I found:
I will need something for the top of the head. I changed the skin of the body to give it a weathered look to fit better with the head (which I give a weathered look overall, not just the front). The original head has closed eyes so I had to guess where the eyes would be when open for the fitting. I then replaced with library eyes. What I like is that you can then go back to the model to make adjustments, which allowed me to give the eyes a better fit.
By jarretttowe - 10 Years Ago
The buddha looks great!
CrazyTalk 8
lol!! :w00t:
By Zeronimo - 10 Years Ago
this is my first fairly satisfactory result. apart from the inside edge of the lips that are a little too dark. I think I should be able to improve that.
https://www.youtube.com/watch?v=DOgJavcM3Ng
By ed3dlux - 10 Years Ago
Whitney Houston
nice one, very clean...that would render very nice in indigo!
By Rykie Milky - 10 Years Ago
JP was missing a friend, so I decided to try and create a female companion for him. There was a lot of trial and error creating her and I think I am happy with the end result. Unfortunately I don't have the best graphics card so it might look slightly artificial around the edges. Currently I am working on a course and she will be used as one of the presenters. I used the default TTS for the audio and lip sync for this sample.
I am sure that JP will be delighted as she is a Nice Character
I'm sorry to see so many cancer patients going through severe chemotherapy threatment. Where's the hair folks?? Why do you leave it out?
On the other hand I'm glad to see that CT8 is great for creating aliens and monsters etc. Hmmm....
O' Brixtor, I left the hair out purely for demonstration purposes to showcase the head. There are a few posts that mentioned that users were struggling with the quality etc. I will try to provide a working sample of Cam tomorrow.
On another note about the hair. I wish reallusion would just sell the hair packs separately. I don't wan't the party pack, so as a user I find it rather disappointing that one has to purchase a bundle to to get the hair.
Another attempt to show Cam in full gear. The background image is one I captured at Hampton Court Palace last year.
By ledlight - 10 Years Ago
For my first attempt with CrazyTalk I used a black and white photo of Jim Morrison and an old interview sound bite.
The hair is horrible, but was closest to his long hair.
I don't quite understand how to replace the photo skin texture completely with some new skin texture? I guess I need to take it into CC for that?
Anyway, I had fun.. the lip syncing really is cool. The puppet animation is great. I can see that with some practice these heads will get more realistic and the animation more natural.
One issue or bug I had was with selecting the lip sync key frames on the timeline. Often I can't select them with the mouse, I click them but they don't highlight. Not sure what's going on there, but I think it's a bug. Sometimes they select, sometimes not. Also I don't know how to nudge or move the lip sync keyframes left or right on the timeline?
Hi Redrum,
Unfortunately the skin tone is determined by the original image. So the only way to resolve this is to use a photo editing program and repaint the image in color. Alternatively, find a color image.
What I do in Photoshop first is to color the B/W image -- really easy to do and there are lots of online tutorials.
I've been getting real good results with this approach.
By Tomasz F - 10 Years Ago
Hi there, This is my first attempt to make a 3d head in CT8. It is just a front face and am quite happy with the effect. Tomasz Lis is a polish journalist, I have found the audio, de-noised it in Audition CC. The only problem I could notice is strange edges of the mouth while talking, but will give it a closer look with next attempt. I changed the News background slightly, didn't correct the eyes. Fortunately, I could find the good hairstyle. Original photo included. Also, I just wonder if there is a way to mix the actors styles, so take the hairstyle from one and shirt or hat from the other?
Another black and white photo not happy with this version either, lol, it doesn't look like him. Mouth movements aren't that smooth either, even though I used smoothing and spent ages manually adjusting.
photos
I am currently working on Robin Williams.
It is a work in progress, The eyes need some work.
By william.carey30 - 10 Years Ago
Some heads I've made:
By Snarp Farkle - 10 Years Ago
This one was from and old photo I had of a friends clay sculpture of Tony Blair, personally I don't see the resemblance but don't tell him I said so. lol
By bobdoyle - 10 Years Ago
So this was a test that kept growing. This is an animated person who's face is based on a photograph of myself (but you wouldn't be able to make the connection - and I still have my hair). I just hit "record" and ad-libbed the "monologue." I spent a little extra time on the visemes to try to make the words look right, but there is still work to do. I think the best way is to delete everything the audio "creates" for you, and then do your own. Time-consuming, but much more realistic results. I didn't do that here, so this is a blend of what they generated with some tweaking on my part - but not perfect. It was rendered against a green background and then composited with stock video in Sony Vegas with some sound effects and simulated camera movement and motion blur added in Vegas, mostly with the HitFilm plugins.
^^ Nice work with the background effect and lighting.
I agree that more realistic results are achieved by deleting everything the audio creates and doing it all manually. Even then, perfection is difficult.
I was hoping the smoothing option would be the solution to the "mouth flap" issue, whereby the mouth judders too rapidly at times, unnaturally. But sadly it doesn't prevent that completely. I feel the application could improve the smoothing to avoid this unwanted side effect. Although our mouths move quickly, our mouths don't flicker in a mechanical way, and even using maximum smoothing doesn't eliminate the problem.
Agree on all points. Reallusion has come a very long way with the technology, and it's difficult to complain with the price point of this. If you spend the TIME, the tools are there to create some really amazing things...I just think too many people rush the process with the "just a few clicks" mentality. I know I'M guilty of it, but as I play with the visemes more, I see what a HUGE difference those little tweaks in the mouth can make on the overall quality of the animation. Such a small thing, but psychologically super-important to portray any semblance of realism - and that "mouth flutter" thing is a prime example of how any "illusion" is quickly disrupted when you see something so unnatural.
By captainpat - 10 Years Ago
Great work Bob. Thoroughly enjoyed watching.
Great work Bob. Thoroughly enjoyed watching. Sorry it repeated and I am not sure how to delete. But take it as two compliments!
Thanks so much for the positive feedback! :)
I just upgraded to CrazyTalk8. CrazyTalk 7 was fun also and I got to make a TV Ad with it animating some sheep. And now I see many more possibilities with 8. I created the head from scratch in Makehuman and then used the TTS On-demand to experiment with voice - the second voice is mine. I found that the US and Uk voices differ in the correct pronunciation of words (not talking accents here). I also used Final Cut Pro X, Adobe Audition and Affinity Photo. It has been a steep but fun learning curve. Well done to the guys who continue to create this program.
By Alien Maniac - 10 Years Ago
CT 8 Pipeline v. 8.03 Test one. Create head. Made head from character image in IC 6 Pro then to CT 8 P. https://www.youtube.com/watch?v=OIvIRby2t-0
CrazyTalk 8 Pipeline. Created head> from A photo. added voice, motion and expressions. https://www.youtube.com/watch?v=YZS2_RpDMFo&feature=youtu.be
Ahh Mr Pose from iclone converted in Crazytalk 8 https://www.youtube.com/watch?v=GOnccpMSE0M&feature=youtu.be
A digital artwork converted in Crazytalk 8 to a talking character. https://www.youtube.com/watch?v=2vCRCumvq-A&feature=youtu.be
By mortalez - 10 Years Ago
I hope you guys like.
This is a test using the new Edit Mesh feature of Character Creator. The head was done in CrazyTalk 8 using the Oxana reference photo provided by RL.
Here is a close-up of the character:
G3 character, iClone 5.
By tongancrusader - 10 Years Ago
this is u...
By vepop - 10 Years Ago
My 1st attempt using CrazyTalk 8 :-
Still have no clue on how to make realistic face expression.
By Mythcons - 10 Years Ago
Zen Master Hotei has a message for his haters on the Internets.
[YouTube]https://www.youtube.com/watch?v=3XE2mx67n6s&feature=youtu.be[/YouTube]
I loaded up my Raijin character, with hand painted texture, into CrazyTalk. He is lip-syncing a line from the Day the Earth Stood Still.
My 2nd attempt ... tq.
By adgoulding - 10 Years Ago
Whoops - this should be in CTA 2
Whoops this should be in CTA 2 - apologies.
By rogyru - 10 Years Ago
Bit fun with Mr Trump and CT, never realised it had its own showcase section , any feedback about compostion is welcome
By theschemer - 10 Years Ago
Where did you get those great dance move motions near the end?? Good job. :)
theschemer (11/14/2016) Where did you get those great dance move motions near the end?? Good job. :)
Thanks , the dance moves are a mix, some converted from the Carneigie Mellon Capture Database and some converted from Henmations mocap data off the secondlife market place
By dwacon - 10 Years Ago
My first attempt at a Donald Trump character. Still learning how to manipulate a photo without it morphing unrealistically. Also... need to find a Trump voice impersonator.
By tcbasset - 10 Years Ago
tcbasset (11/23/2016)
Nice work Burrddddsssss , like the comedy take on the whole birds are dinasours
Yeah crazy huh? :)
rogyrue (11/17/2016)
Thanks , the dance moves are a mix, some converted from the Carneigie Mellon Capture Database and some converted from Henmations mocap data off the secondlife market place Thank you. :)
Napoleon Crossing the Alps
French Version
By commandersirsnowy - 9 Years Ago
Hi Reallusion Forum! It's Sir Snowy, the ItalianCats-A-Nova! Our short animation film, "Sir Snowy's Mummy's Day Adventure-2016" using Crazy Talk was nominated at the Film Boy Film Festival in California and out of over 800 short films (live actors and animations) placed number 15 ! We were so happy! Link: Sir Snowy's Mummy's Day Adventure-2016 We're a charity (Sir Snowy Projects) that helps abandoned,abused and homeless kitties get a chance at happiness. We also help children and adults with special needs via animal assisted therapy. Hope you enjoy the video!
By AirBeagle1 - 9 Years Ago
First completed physics video using CT8... Considering optimization routes for the future such as 1) streamlining the workflow for future videos 2) improving the 3D model (especially hair) 3) utilizing other characters (specific request for a beagle-type character) 4) figuring out how to integrate with CTA.
Make it a great day!
By Lernakow - 9 Years Ago
It's good but it's static. As for your model I believe you could make the head a bit bigger (no need to remake the head, there's a tool for body / head scale), right now the neck looks like you spend too much time in the gym. As for editing - take a look at how they make documentaries or popular science TV shows. The host (or an interviewee) talks about something in a close up or semi close up (with or without a rule of thirds). Then the voice continues but the video cuts to some visualization (like your whiteboard). Then back to the speaker, then back to visuals - give viewers one thing to focus on at a time. But you know what? You've made a video. I'm studying the medium, preparing myself, overthinking everything, doing nothing. You've made a video. You rock!
By FrankGarrett316 - 9 Years Ago
I appreciate this post, because I was considering getting CT8 as I seriously need a Trump character, and this kind of shows me that I should probably hold off on this endeavor, at least for now.
You made the face look great in CT8, but the way the software imports the character into CC/iClone loses a lot of detail (not your fault) and won't serve the realism I'm going for.
I guess I'll either have to buy a model from a third party product (of which only one good one exists at the moment, and it costs.............$399.00 for the model, and it's not rigged), or..............just meticulously try to shape and sculpt my own Donald character in Character Creator by finding the right "head" in the RL 100 pack, and then shaping it to look like him.
Or I guess just make him as a G5 character and use his image? Or will that just look the same way as it did in the finished version above?
By animagic - 9 Years Ago
The post you quote is over a year old and RL has worked on the differences between heads as they appear in CT and CC.
I think that improvements have been made. I searched for a suitable Trump photo and tried to create my own Trump. This is the result in CC 2.0 after a bit of work:
The hair is a challenge: I used the pompadour hair and changed the coloring. The character could also be made older obviously.
It takes practice to get good results; mine were initially not that great when CT8 just came out. One problem is to find a suitable photo that is evenly lit, mouth closed, etc.
By ctuber - 9 Years Ago
Hey everybody. Here's a little music video I created for my YouTube Channel, BRT TV. I used CrazyTalk 8 for most of the characters. Please let me know what you think. Thanks
By rogyru - 9 Years Ago
He flew my drone so in return i sent him to the moon and put him through CrazyTalk and Hitfilm :)
By Ziggy72 - 9 Years Ago
...and the moral of the story is - don't drop a tab when you fly your drone lol. Very silly, I like :)
By swashbucklingfox - 9 Years Ago
Nice!
By pcizaire - 9 Years Ago
On my website I have added some simple videos made with Crazytalk + Das Studio 2D renders for children and pupils to learn some things quickly : http://cartoon6r.free.fr ! I use voice effects from Crazytalk for various characters. This option is great ! 6R
By larryjbiz - 9 Years Ago
         [quote][/quote]
Haven't figure out this posting thing yet. Guest I don't do it enough. But above is some CC characters I created through Crazytalk 8. I am Not very good at modeling and haven't figure out how to alter object files without getting an error that I changed the vertex count or something and now the files are incompatible.
So I've tried to use crazytalk to capture some of the object shape along with the texture as a way to model some CC heads, and create some morphs.
Above is the result.
Thanks for looking. LarryJ
By Tarampa Studios - 9 Years Ago
"Crazytalking" with iClone To create this fun little project, I used the following workflow: Step 1: Drank a few wines, wrote the limerick and recorded the voice on my phone using the free Voice Changer app by Scoompa Step 2: Googled some fun pics and paintings to prepare a consistent theme in Photoshop. Step 3: Animated and Rendered each image with voice recordings loaded into Crazytalk. Step 4: Control-Dragged those Rendered avis from Crazytalk into iClone and attached them all behind the png of an empty picture frame. Step 5: Animated the Paintings and Picture Frame motions with SFX loaded onto the Picture Frame and music on the Wall behind it. Then I rendered from iClone and uploaded straight to Youtube without needing any additional editing software. Total Project Time: 4 hours. (Note: The feet are just a png with opacity set to zero until needed. )
