Techincal Issue:: Objects snap to origin when opening iClone 6 file
https://forum.reallusion.com/Topic263172.aspx
Print Topic | Close Window
By cyndi.foster - 11 Years Ago
I'm currently dealing with a bit of a weird issue in iClone 6, and I'm hoping maybe someone might have a solution.
Yesterday I made a full News Room set in iClone 6 with lights placed and everything. Sadly the only before image I have is the iClone 6's file icon thumbnail that shows a top view of the set.
https://forum.reallusion.com/uploads/images/4d5db610-1995-4cf4-887b-b3f8.jpg
This morning, however to my surprise, when I open this same file with the same file icon thumbnail, it appear like all objects have been snapped to the origin point.
:internal scream:
Does anyone know about this issue, what might be causing this, or how to fix it?
Thanks so much for any help
By mark - 11 Years Ago
Sounds like there's an added keyframe in the timeline for your objects.If you play or scroll the payhead do the objects move into the correct position?
If so you have an extra keyframe in the timeline for your objects.
It's usually best to start building your set at frame 01 if you start later iClone will automatically add another keyframe.
I would scroll the playhead till most everything looks correct then you can right-click on your objects to reveal the menu that allows you to delete keyframes. That should get you back to normal.
Oh my, bad case of the Mondays. That was totally it. :face palm:
Thanks so much for your answer. I was freaking out a bit :D
By wires - 11 Years Ago
Welcome to the Forum Cyndi.
I see that Mark beat me to the post.:)
