Character Creator and Character Poly Count
https://forum.reallusion.com/Topic263115.aspx
Print Topic | Close Window
By Merry Paw - 11 Years Ago
I have not seen anything yet, but is CC able to lower the poly count of it's characters for a crowd scene?  If not, that might be a nice addition.
However a thought along these lines as I have 3DXchange pipeline, if I exported a finished CC character out to Blender, lowered the poly count and imported back in, is this possible and could this be a possible solution to group characters?
Thank you!
By animagic - 11 Years Ago
Polycount within iClone is fixed and cannot be changed. You could export the character and reduce the polys, but it would no longer be a standard iClone character. You would have to re-rig it probably and then import back as a non-standard character.
For crowds, where details are often less important, you could use low-poly characters, which are available in the MarketPlace.
EDIT: I try to get rid of the light-blue background, but I can't...:unsure:
By CaseClosed - 11 Years Ago
This is a fantastic idea. Have two or three different poly-count versions. A high-poly-count would be great for detailed closeups and for film quality rather than game-engine quality.
By justaviking - 11 Years Ago
Do CC characters have a variable level of detail (LOD), like a Speed Tree props?  That would be really handy.
Speedtree props have a variable level of detail?
By mtakerkart - 11 Years Ago
That's unfortunate, though I respect the content creators here as I'm a 3D modeler myself trying to avoid the little bits that add up is helpful for someone on a fixed income.
