Character Fade Out?
https://forum.reallusion.com/Topic262685.aspx
Print Topic | Close Window
By bud_20121023184423262 - 11 Years Ago
Hi All,
Anyone know of an easy way to fade out a character's visibility?
The few times I had to do it, I've done so by keyframing all the character's materials. But it seems like there should be an easier way. Is there?
By animagic - 11 Years Ago
bud_20121023184423262 (12/4/2015)
Hi All,
Not that I know of. I've used the same method. It least now all relevant materials are in one list. It's not great because there is a difference in the "fade out" quality of different materials.
By mark - 11 Years Ago
At around 2:00 mins into my little Pinhead video I created the transparent ghost effect by rendering the scene 2 times. One with the ghost and one without. I took the two clips into my NLE, SONY Vegas, and put one clip over the other in the timeline and adjusted the opacity to create the ghost effect.
By justaviking - 11 Years Ago
mark (12/4/2015)
I was thinking the exact same thing, and you provided proof it works.
Thanks!
...simple yet effective!!!!:P:P:P
animagic (12/4/2015)
I've noticed the varying fadeout speeds of the various materials as well.
mark (12/4/2015)
Thank you, Mark,
That's exactly how I solved the problem the first time I'd run into it. I might go back to that method. It takes forever to select all the materials on a character.
mark (12/4/2015)
By the way, now I'm watching the whole thing -- AWESOME work!
Thanks! And the silly little project actually served a purpose!!! Who knew??!!:P:P:P
By Lord Ashes - 11 Years Ago
As far as I know you can use the character's Opacity to make them fade out.
I used this technique to sort of fade one version of the character into another using the following method:
1. Insert character one
2. Insert character two in the same space as character one
3. On the time line, at frame 1, add a key frame for character one and set the Opacity to 100
4. On the time line, at frame 1, add a key frame for character two and set the Opacity to 0
5. On the time line, at frame 300 (for example), add a key frame for character one and set the Opacity to 0
6. On the time line, at frame 300 (for example), add a key frame for character two and set the Opacity to 100
In you case all you would do is the one character.
I don't recall, at the moment (without the project open) if I had to set the Opacity of each character's material (e.g. Face, Body, etc) individually or if I managed to apply the Opacity to the overall character.
